Whirlpool SF380LEKQ oven w/ DSI won't stay lit
#1
Posted 12 February 2007 - 09:54 AM
This unit has direct spark ignition (DSI), so no hot surface ignitor. Ignitor spark is strong and in proper location near burner. Burner is clean with no soot or buildup around orifices.
Broiler burner is virtually identical and works fine.
Gas valve solenoids read proper and equal resistance.
I'm not real familiar with DSI, so can't understand where the required flame sensor is located (guarantees gas ignition or shuts valve). Nothing shows up in exploded parts diagram, just a single temp sensor for whole oven cavity. This flame sensor could also be the culprit, but I'm in the dark as to what/where it is.
Owner noticed display blinking twice when the failure occurs, but no fault codes are displayed. He's convinced that the control board is the problem, but it's the most expensive part in the oven and I'd like to make sure.
It will spark when trying to re-ignite, at least we can hear strong ticking.
Suspecting flame sensor (mystery part), control board (could explain most control problems), ignitor board (intermittent/unreliable), gas valve (close to flame, could be weak when heated). Would like to pick the right component the first time so we don't shotgun three or four expensive parts to finally solve the problem. If anybody has good ideas, I'd like to hear them.
Jim
#2
Posted 12 February 2007 - 09:58 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 12 February 2007 - 10:04 AM
- kdog and Comstock_Services like this
#4
Posted 12 February 2007 - 10:52 AM
Jim
#5
Posted 22 February 2007 - 04:49 AM
The old burner had only four gas ports near the igniter electrode and the igniter shield has only minimal air holes (more solid):
file:///f:dscn0951.jpg
The new burner has eight igniter gas ports and the shield has much more open area:
file:///f:dscn0948.jpg
So with more fuel and air supply, the burner lights more reliably.
Jim
- Comstock_Services likes this
