Kenmore Dryer 110.66722694
13 replies to this topic
#1 FStrickland
FStrickland
  • 5 posts
Posted 21 February 2007 - 03:30 AM
My Series 70 Kenmore dryer has literally over night decided to stop co-operating. In either Auto-Dry or Timed Dry modes it will not turn off. I have made sure that the vent filter and vent tube are clear and clean. I have replaced the timer and get the same results. The dryer heats up and will dry the clothes, yet the timer never moves from where it was set when the dryer was turned on. Any help would be appreciated.
#2 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
  • Flavorite Brew:Busch
Posted 21 February 2007 - 04:29 AM
the timer motor wont move or get energy until the moister sensor stops detecting dampness in the clothes
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#3 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
Posted 21 February 2007 - 04:32 AM
if you look on the back bulkhead inside the machine you will see the moisture sensors right there a black thingie with two metal stripes  as the clothes rub against this they make resistance contact if they are damp . when it detects no more damp then it energizes the timer and then the thang shuts off.
-old Irish saying
#4 Pegi
Pegi
  • 13,120 posts
Posted 21 February 2007 - 05:14 AM
Is true the timer will not advance in auto if the heat circuit is not doing its thing, but should advance in timed dry no matter what the heat circuit is doing, let me see what is in your dryer...be back in a bit...110.66722694
#5 Pegi
Pegi
  • 13,120 posts
Posted 21 February 2007 - 05:26 AM
Ok, this looks to take the 3976577 timer which has the 240 volt timer motor, did you order the right one???
#6 FStrickland
FStrickland
  • 5 posts
Posted 21 February 2007 - 06:01 AM
Hmm... thought I did. The new one looks exactly like the old one. Will have to check it tonight when I get home. One of my co-workers suggested at lunch that the resistor could be bad? I'm not an electrician, so might he have a legit thought process?
#7 Pegi
Pegi
  • 13,120 posts
Posted 21 February 2007 - 06:15 AM
You are correct, a resister on or attached to the timer has to do with the timer advancing in automatic, does not come into play in timed dry....however I do not see a resister attached to the timer in the breakdown for your model number which would make sense because the dryers with the 240 volt timer motors do not have resisters, this 240 volt timer motor was implimented to take the place of the resister...but is odd the new timer is doing the same thing as the old one..are we sure there is 240 volts to the dryer???
#8 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
Posted 21 February 2007 - 06:17 AM
their is a resister its part number 15 on the page where the timer is
-old Irish saying
#9 FStrickland
FStrickland
  • 5 posts
Posted 21 February 2007 - 06:28 AM
I'm sure there is 220. I use the same outlet for my air compressor when I need it and I checked to make sure the air compressor worked when the dryer started acting up Sunday night. Would I need an electrician to check for 240 or can I safely do it with a volt meter?
#10 Pegi
Pegi
  • 13,120 posts
Posted 21 February 2007 - 06:37 AM
Yes, I saw that reference # 37, however there is no resister on the timer itself to advance the timer in auto if it has the 250 volt timer motor which it shows this model number to have??  Since this is a Whirlpool dryer with the Kenmore model number cannot compare it against the ones listed in this SERVICE POINTER from Whirlpool adressing this change....look on your timer when you get home and see what voltage is stated.
#11 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
Posted 21 February 2007 - 09:36 AM
yeah that was what that resister was for to keep the dang timer motor from being torched . how do I know this? I have fried a timer by jumping out that resister .bad idea
-old Irish saying
#12 FStrickland
FStrickland
  • 5 posts
Posted 21 February 2007 - 04:03 PM
Okay, I compared the 2 timers and they have identical information on them as follows: Model M460-G, 1/3hp, 15/7.5A, 125/250VAC. I also checked the outlet and it pegged my volt meter at 240 volts. I did notice 2 things tonight; 1) the plastic on one of the female recepticles on the outlet appeared to be partially melted, the plastic was definitely discolored and 2) the paint on the dryer where the resistor sits on the metal surface was brown  and the clear plastic "sleeve" the the resistor sits in was burned where it touches the metal surface of the dryer. Might either of these be causing my problems?
Thanks.
#13 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
Posted 22 February 2007 - 04:16 AM
you are supposed to change the resister when you put the new timer on and the resister is a seperate part
-old Irish saying
#14 FStrickland
FStrickland
  • 5 posts
Posted 26 February 2007 - 12:00 PM
Got a new resistor and installed it on Saturday, dryer works like new. Sunday, just for the heck of it, I reinstalled the old timer and it worked also! Would not have thought that the resistor would have been the only reason for the issues, but looks like it was.
Thanks fo rthe help.
