dc
Maytag A7300
2 posts in this topic
The Maytag A7300 washer is leaking water out of the front. I could not figure out how to take off the outer panel to look inside. There are three screws at the bottom of each side as well as several on the back; the sides and back are one continuous piece while the front and top each are separate. I thought that there would be an easier way to open the machine other than removing the three panels. Can you please help with suggestions for the leak and on opening up the machine?
Thank you
2 screws at the bottom of the front panel-front panel comes outward from the bottom
