kenmore washer not drain all of the water. neighbor say it the direct drive coupling
3 replies to this topic
#1 Guest_funnyface1142@aol.com_*
  • Lurking at the Threshold
Posted 10 April 2005 - 08:41 AM
 the water is not  draining all the way . there is still water in the washing machines and the clothes are still wet.
#2 XNSXMANNY
XNSXMANNY
    Ikkō-ikki
  • Master Appliantologist
  • 42 posts
Posted 10 April 2005 - 10:15 AM
your neighbor is wrong it has nothing to do with the coupler. something is blocking the water discharge. check the pump for a sock or  something stuck in there.
#3 kc-cat
kc-cat
    Ikkō-ikki
  • 42 posts
Posted 04 September 2007 - 05:57 PM
When you say "check the pump for a sock or something", how do you do that?  I mean, do you have to take the pump apart, take off a hose, etc.???
Thanks, because I have the same problem.  And with a little guidance, I think I'll be able to do it myself.
When you're at the end of your rope, tie a knot and hang on!
#4 Guest__*
Guest__*
Posted 05 September 2007 - 12:05 AM
Hi,
Here is a video that will show you how.
http://appliancejunk.com/forums/index.php?topic=68.0
You should also take a look at the drain hose on the back of the washer to make sure it is not kinked anyplace. Like were it connects to the washer or were it goes into the drain/stand pipe.
