Maytag Dishwasher fills by itself overnight
3 replies to this topic
#1 wuchak
wuchak
  • 8 posts
Posted 10 April 2005 - 10:59 AM
I have a 4 year old Maytag dishwasher, MDB71000AWW, that has developed a problem. It fills by itself overnight. When it does this it seems to be filling to the point that it leaks. It just started doing this after I replaced the hot water heater in the house.
Before I remove the trim to get underneath it I was wondering if there is something I should try.
Brian
#2 mopar X
mopar X
    Yamabushi
  • Master Appliantologist
  • 76 posts
Posted 10 April 2005 - 11:43 AM
Time to replace the water valve located behind botom panel
#3 wuchak
wuchak
  • 8 posts
Posted 10 April 2005 - 02:10 PM
Thank-you Mopar.
#4 ApplianceTech
ApplianceTech
  • 3 posts
Posted 28 April 2005 - 06:16 PM
You may be interested to know that on occasion after water heaters have been replaced there can be a good deal of sediment in the hot water lines. It is a good idea to flush all hot water lines before you use any appliances with the new water heater as the sediment can collect on the water inlet valve screens.
