bundyfmly
Whirlpool Refrig
3 posts in this topic
I have a Whirlpool Gold Refrigerator, about 6-7 years old, model # GD22DQXFW00.  My in-door water dispenser is not working.  Changed out the water filter and inlet water valve in back of refrigerator, but still not working.  Lines are clear but no water is entering the water line for the dispenser.  Ice maker and ice dispenser in door is working fine.  I had taken out the small light bulb for the dispenser recently.  Could water have gotten inside where the light bulb is supposed to go and shorted it out?   HELP!
The actuating switch might be broken or the switch actuating lever may be worn and not actuating the switch.  One test for this is to depress the lever for water and measure for 120v at the water inlet valve in back of the fridge.  No voltage = bad switch.  Good volage = water supply or valve problem.
I will try this.  Will let you know the results.  Thank you for your quick response.   :)
