F1 & F3 Kenmore Flashing/Beeping Codes
#1
Guest_Fernando_*
Posted 30 March 2005 - 09:40 AM
Hello I own a Kenmore Stove (Ceran top) ,
I got the flashing F1 and beeping
going on every time I plug the Stove.
If I disconet the Oven Sensor the beeing stops
and I get the F3 code.
Can someone help me understand what's going on
thanks in advance
F
#2
Posted 30 March 2005 - 10:25 AM
http://fixitnow.com/...temperature.htm
More information on this problem here.
#3
Posted 02 April 2005 - 05:47 AM
The EEPROM is a separate chip on my control board. It's memory got corrupted on the power cycle and unfortunately there is to way to get it back. Alas, it looks like my only option is to shell out $175 for a new board.
Unless someone knows where I can get the programming file for the chip... it wouldn't be too difficult to pop it out and reprogram it. Of course, absolutely no help from Sears or Whirlpool on this issue...
Grrr!
#4
Posted 02 April 2005 - 02:55 PM
Yesterday we had a power glitch and immediately after the power came back on my Kenmore stove (665.75822) was displaying an E1-F1 error code. Found the tech sheet which tells me that the EEPROM checksum is bad. Since the problem happened right after a power glitch I suspect it ain't the keypad. Board voltages look good.
Grrr!
You may try to unplug the stove for 5 to 10 minutes and see whether it returns to normal or not.
#5
Posted 03 April 2005 - 12:32 AM
Hello, my memorable friend. You have adeptly identified the problem with your Whirlpool-built range. The programming information you seek for this microchip is a closely guarded secret and is the object of intense industrial espionage. Even the appliance manufacturers themselves do not have this information because they purchase these boards as an pre-fabricated assembly from a third-party electronics manufacturer deep in the bowels of Singapore. They merely provide the operations specifications of the ERC and it is built to those parameters. While this information gets you no closer to your repair, I pray it gives you a larger perspective on the issue and thus helps to ameliorate your anguish and despair over your range.The EEPROM is a separate chip on my control board. It's memory got corrupted on the power cycle and unfortunately there is to way to get it back. Alas, it looks like my only option is to shell out $175 for a new board.
Allahu Akbar!
#6
Posted 26 December 2005 - 10:26 AM
I have the same problem.
I have to turn the breaker off. When I turn it on the oven and all the burners work. Just when I turn of the stove off it beeps and flashes F1.SO I turn the breaker off.
I have read some good things on your website.
I want to check the oven sensor, but I can't figure out how to remove it. Does it has to be unplugged from the back of the stove? I took the two screws out from the inside holding it in place.But it will not come out.My model is Kenmore 911.4652090. Can anybody please help me.
#7
Posted 13 September 2006 - 07:30 AM
#8
Posted 25 June 2007 - 06:41 PM
- Ken Olson, Digital Equipment Corporation (1977)
#9
Posted 26 June 2007 - 05:46 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
This topic is locked
