peterpa
Whirlpool Duet Washer -- Not Starting
8 posts in this topic
Our Whirlpool Duet Washer from 2004, GHW9250ML1, will not start. It is getting power, the timer is blinking at us, and we can apply the settings and time. When we start the washer, the door locks and then quickly unlocks and does nothing ... the timer just continues to blink at us ... The unit can not be powered off -- it comes right back after unplugging.
Any ideas?
Thanks in advance,
Paul Peterson
Sounds like a bad control board, I believe the controls will have a 2 year warranty on these, I would suggest you call Whirlpool with your Model and Serial number and date of purchase to see if this is under warranty?  And when in 2004 did you buy these, the whole unit may be under warranty.
bought early 2004. Parts covered only (Remanufactured). Any estimate to replace the control panel?
I do not know since we do not do warranty on these, and assuming it might be a bad control board, looks to be around $275.00 from Sears.  You need to get some more input from others who do these but sounds like you need to call for warranty service, as there could be something else causing this unit to act this way.
Cool Dude, knew it would be, that is why I posted the Sears price....:cool:
My pricing question is really around the service call and labor charge to swap out the control board.  The control board should be undert warranty.
Thanks.
That is why you will be calling for authorized service, this forum will not help you there.
