kitchenaid kudy24sealo stuck in clean cylce
  • This topic is locked This topic is locked
1 reply to this topic
#1 Guest_idle_*
Guest_idle_*
  • Lurking at the Threshold
Posted 10 April 2005 - 04:01 PM
no matter  what settings  when  you click start it  goes to clean cycle
                thanks  for any help
  • 24,707 posts
Posted 11 April 2005 - 01:42 AM
Probably a bad water heat thermostat.  Will it advance in the cycle if you turn off the water heat option?
