Whirlpool Oven SF379LEK
18 replies to this topic
#1 jzx6rs
jzx6rs
  • 5 posts
Posted 24 June 2005 - 02:04 AM
Hello. I have a Whirlpool Oven model number SF379LEK which is approximatly 3 years old.
When turning the oven on to a preheat, the ignitor will make 4 "clicks" or so and sometimes the burner will not light. Sometimes this happens during an oven cooking cycle as well. This condition is random and does not always happen. How I noticed the last time is that thinking the oven was at 350 I checked on the cooking process 30-40 minutes later and noticed the oven temperature was down to 200 or so.
Thank you very much for your input
#2 kdog
    RoughShod
  • 7,466 posts
Posted 24 June 2005 - 04:47 AM
this unit uses a direct spark ignition system which will attempt to ignite,but if it doesn't,the control defaults to a shut down mode for 5 minutes to allow purging. i have run in to a couple of issues with them,all due to the feed wire to the ignitor itself; the wire runs down the rear of the range and is secured to the chassis w/metal clips. after time,the meatal clips chaffe through the wire insulation and since it is a high voltage circuit,combined with a feedback circuit for flame sensing; creates a ground situation which ceases ignition.  i found the best cure was to take some good,heavy guage,well insulated range wire(high heat insul.) and solder a terminal at one end,restring the whole circuit,paying special note to secure to chassis without damaging insulation.
#3 Pegi
Pegi
  • 13,120 posts
Posted 24 June 2005 - 11:05 AM
See if this might address your problem???
[align=left]All 30” Whirlpool Gas Self-Clean[/align]
[align=left]Freestanding Ranges[/align]
[align=left](with Direct Spark Ignition)[/align]
[align=left]MANUFACTURED BETWEEN CODE DATES RK01 THROUGH RR07[/align]
[align=left]􀁺
Oven is shutting off sometime during the Bake cycle[/align]
[align=left]and food is not cooked.[/align]
[align=left]􀁺
Oven will not light, or will light and shuts off.[/align]
[align=left]􀁺
Oven burner ignition is sporadic.[/align]
[align=left]􀁺
Oven may “lockout” after cycling the oven burner at[/align]
[align=left]Bake settings.[/align]
[align=left]􀁺
Oven cools down after “PreHeat”.[/align]
[align=left]CUSTOMER COMPLAINT(S):[/align]
[align=left]CAUSE:[/align]
[align=left]Intermittent bake burner operation due to improper air flow[/align]
[align=left]to the burner.[/align]
[align=left]CORRECTION:[/align]
[align=left]The bake burner and bake ignitor has been modified to[/align]
[align=left]assure consistent oven ignition and performance. Order[/align]
[align=left]and install Kit # 8190618 (new bake burner and bake ignitor[/align]
[align=left]assembly)
[/align]
#4 Pegi
Pegi
  • 13,120 posts
Posted 24 June 2005 - 11:12 AM
Here is another possible cause for this....
#5 kdog
    RoughShod
  • 7,466 posts
Posted 24 June 2005 - 08:31 PM
thanx for that info pegi, i missed that bulletin.
#6 nickfixit
nickfixit
  • 2,190 posts
  • Flavorite Brew:Glen Livit
Posted 25 June 2005 - 02:20 AM
The new burner design does work much better. I've used many of theem with good results.
Nick
#7 jahjahbinks
jahjahbinks
    idoit / voyer/ anarcist
  • 287 posts
  • Flavorite Brew:ABSOLUT & GREEN TEA
Posted 25 June 2005 - 06:32 PM
pegi ,that is only a bandaid i have tracked most or the reworks i have done and 40% come back with related problems and the only solution is to replace the burner again this is also common to the kenmore 665 gas range model (same range)
SHE WHO HAS THE MONEY GETS HIS APPLIANCES REPAIRED
Currently serving EVERYTHING
#8 Pegi
Pegi
  • 13,120 posts
Posted 25 June 2005 - 06:50 PM
Boy, and I thought W/P made good products, is sure crappy the poor customer has to pay and pay again to repair the same range over and over again.....sigh....:?
#9 jahjahbinks
jahjahbinks
  • 287 posts
Posted 26 June 2005 - 05:09 PM
i love whirlpool products , the worst they are the better for me sence i dont sell them however it is so sad that the averege joe dosent know that the whole whirlpool appliance line is flawed with something or another , for example while i worked for sears we had a warehouse full of whirlpool and kenmore 665 ranges ,as a service tech when i would get a call on one or seven i would write a special no# on the back so i could track how many times i saw this unit and how many homes i saw it in for the same repair, when we contacted whirlpool the engineers said they just didn`t know how to fix it  so they handed us the burner bandaid and the same goes for the microwaves and the he3`s washer and dryers. so as you can see whirlpool is a service techs best friend.
#10 Pegi
Pegi
  • 13,120 posts
Posted 26 June 2005 - 05:29 PM
That is not right.....sigh....:(
#11 jzx6rs
jzx6rs
  • 5 posts
Posted 07 July 2005 - 02:14 AM
Thanks Pegi for the recommendation. Since I live close to repairclinic.com, I stopped in there yesterday and picked up part 8190618 and after 3 hours of oven bake time I have not experienced the problem again
Installation was a breeze.
Thanks Again
#12 Pegi
Pegi
  • 13,120 posts
Posted 07 July 2005 - 09:06 AM
Cool, thanks for letting us know!!   We won another war, well at least for now....
#13 Lurker_new guy_*
Lurker_new guy_*
  • Lurking at the Threshold
Posted 14 December 2005 - 07:25 AM
Just bought the part. Was wondering if anyone can point me to the installation instructions.
Thanks.
#14 Pegi
Pegi
  • 13,120 posts
Posted 14 December 2005 - 07:52 AM
New Guy, you just bought what part for what appliance....brand and model number.
#15 Lurker_new guy_*
Lurker_new guy_*
Posted 14 December 2005 - 09:14 AM
Sorry :-)
I got the 'Kit # 8190618' - the burner igniter assembly.
For Whirlpool gas range gs465leks.
This thread pretty much describes my problem
http://applianceguru...orum1/1461.html
#16 jzx6rs
jzx6rs
  • 5 posts
Posted 14 December 2005 - 10:13 AM
Hello New Guy
I installed this part back in July. Remove the oven racks from the oven and then use a screwdriver and remove I believe 3 screws from the bottom cover of the oven baking area. Remove the cover and there you will see the burner/ignitor. Use a screwdriver and remove I believe 2 screws that hold the burner/ignitor in place and also remove the wire that attaches to the ignitor. Now the old burner/ignitor is removed. Installation is reversed from the above.
Hopefully this helps
#17 Lurker_new guy_*
Lurker_new guy_*
Posted 14 December 2005 - 10:35 AM
Thanks, jzx6rs.
That's pretty much what i did. ended up not being that difficult. Tested, seems to be working now.
#18 jzx6rs
jzx6rs
  • 5 posts
Posted 15 December 2005 - 04:56 AM
Great....gladded it worked for you... I havent had a problem since I made the repair....
#19 jzx6rs
jzx6rs
  • 5 posts
Posted 19 September 2006 - 03:01 AM
Well, unfortunatley after only a little over a year this part has went out again. Sad that an oven is built this way and/or a part last only a year.
Replaced the part, again, and it works great...at least for another year. :(
