Washer won't spin
#1
Posted 29 May 2007 - 02:00 AM
The problem is Wash cycle and agitation works fine when it removes the water to go into the rinse cycle it works fine. I here the pump kick in and the tub slowly spins as it gets rid of more water tub spins faster. But when the washer gets to the final spin cycle after the last rinse cycle. The washer starts to add a little water, (Iassume this is done to balance the load), I see the agaitor turn about a quarter turn and then I see the tub try to turn but doesn't and here them motor make a louder hum as if it is binding. Then the overload trips and I have to wait for the overload to reset.
I can then place the timer anywhere and the washer will work on any portion of the cycle but the final spin cycle. Any Ideas?
#2
Posted 29 May 2007 - 03:20 AM
#3
Posted 29 May 2007 - 03:45 AM
#5
Posted 29 May 2007 - 07:22 AM
#6
Posted 29 May 2007 - 08:53 AM
Personal Info- I am a electronic Tech and a electrician. Unfortunately washer aren't my expertise. I say this to inform anyone that can help me that I do have some electrical knowledge in case the conversation turns technical.
Different observations: Fill is never a problem, the first agitate also no problem. First removing of the water with the pump no problem. First spin in wash cycle didn't work. If I moved the somewhere else on the cycle it seemed to have problems after that with the agitation or spin.
I got underneath and notice a starter cap on the motor. If that is going bad could that cause this problem. I do see something similar to this on my well outside when the caps start to go bad.
I just noticed that the washer a agitate hi and agitate low and and it appears the drain and the spin are the same. It doesn't seem to work on the Hi speed. If I'm correct is this the motor or the cap?
#8
Posted 29 May 2007 - 03:19 PM
#10
Posted 29 May 2007 - 03:36 PM
#11
Posted 29 May 2007 - 03:49 PM
#12
Posted 29 May 2007 - 03:57 PM
#13
Posted 30 May 2007 - 12:36 PM
#14
Posted 30 May 2007 - 02:00 PM
To isolate the problem from a binding issue pull the motor from the gearcase and see if the problem continues. If so move to the next step.
Time to move to the timer circuit. Place the washer in whatever cycle it fails and make the following checks at the motor. Place one lead on White (nuetral) and leave it there. Then check for 120VAC at Blue & then at Yellow(if in agitate) or Red (if in spin). As a final check for the start winding verify 120VAC from Yellow to Red
#15
Posted 30 May 2007 - 02:11 PM
usually when the motor connector is loose i find it pulsates during agitator or spin or both etc... ive never run accross a washer that was overheating due to a loose connector but there is much to be learned.
#16
Posted 30 May 2007 - 09:30 PM
- Ken Olson, Digital Equipment Corporation (1977)
#17
Posted 31 May 2007 - 01:14 PM
that symptom i described mostly happens with the white/orange or Violet wire because loose some where along the way... basically the start winding kicks on and then disengages with hopes that the main run winding will carry it... when the main winding does not have voltage the speed drops and the start winding kicks back in again :) I guess thats what you are saying isnt it lmao..That could be caused by the motor starting over and over with the start winding powered, if the speed drops enough.
#18
Posted 31 May 2007 - 04:17 PM
#19
Posted 31 May 2007 - 07:56 PM
Guess so. Either only start or run winding powers up, will not start properly, and overheats. Well, it wasn't the problem this time.I guess thats what you are saying isnt it lmao..
#20
Posted 31 May 2007 - 11:31 PM
