thedave
bosch dishwasher shu9915uc/u11
2 posts in this topic
Hello,
I have a Bosch dishwasher model number SHU9915UC/U11 serial # FD8105 that needs a new circulation motor.  I pulled the unit out of the cabinet and removed the side panels, but can't figure out how to get it out.  Motor is big and space is small.  Does the base come off?  Or is there a special trick?  Any help would be appreciated.
David
dave- you've entered an area many of us dread.  yes the base can be removed.  i heard of guys that will tip it upside down and remove the base and some will prop up one side with a block of wood, there should be enough room to remove the motor. i don't remember exactly where the screws are but i think front and back and you may have to release the door springs. good luck.
