mtdoc
maytag dishwasher door leak
4 posts in this topic
Maytag dishwasher model # DWU8250AAX. Door leaks bad around edges and dripping on floor. Also have water leaking out of vent in top center of front door.  I assume door gasket is bad, esp.after I removed it and reinstalled.. But it also appears as though water is getting sprayed up into the hole in the lower center of the inside of door. This seems to be the only way water is getting all the way up the interior of the door and leaking to the outside.Thanks for any help.
Check the soap door latch gromet
I taped over the soap door latch. As soon as the spray starts water flows down the side gasket areas and then out the front vent. There is too much leakage to be due to a small leaky soap door gasket.
