How to test components
#1
Posted 04 June 2007 - 02:50 PM
#2
Posted 04 June 2007 - 08:46 PM
Most, if not all CD/DVD drives have a little hole in the front panel somewhere, unbend a big paper clip and insert into hole giving good firm solid push till it stops, the slide tray should then be open enough to finish opening by just a gentle pull by hand.
Eureka, CA 95501
#3
Posted 05 June 2007 - 02:22 PM
#4
Posted 10 June 2007 - 01:48 PM
Sure that the PSU is good all the way? I've run to a couple cases where they became intermittent with missing or inaccurate voltages... 12 and 5V take care of the fans and lights, but for example, 3.3V missing can (and nowadays mostly will) keep anything else from happening.
- Ken Olson, Digital Equipment Corporation (1977)
#5
Posted 13 June 2007 - 12:49 PM
#6
Posted 10 July 2007 - 10:05 PM
#7
Posted 22 August 2007 - 04:24 AM
As for the power supply, the best way to test it is to use a DMM to measure the actual voltage while its powered on, usually best with a cheap PSU tester and a DMM, though you can buy PSU testers that have a DMM function integrated, ie, http://www.frozencpu...tml?id=cgxSC3ND
#8
Posted 26 August 2007 - 10:20 AM
Those are 2 methods you can try.
Mike M
