The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
JohnnyDoItHimself
Water Dispenser Keeps Running
4 posts in this topic
INFO: Hotpoint Fridge Model CSX27DLR
PROBLEM: Water dispenser keeps running.
For 14 years this giant Hotpoint side-by-side has run faithfully. Until the other night when I pushed in the water dispenser in the freezer and felt a little pop. The water wouldn't shut off. Had to turn off the supply valve.
I'm thinking there's a spring that returns the supply valve to the closed position and that it broke. But I couldn't find the part and even if I did, I'm not absolutely sure that is the problem.
So, a few questions, learned ones:
1) How do I access the dispenser mechanism? There's a panel on the inside of the door, which covers the mechanism. How do I get it off without cracking it?
2) Once I access the dispenser, what am I looking for? Do I replace just a spring (if that's broken) or is it a complete unit?
3) What's the part number?
4) What's the beer rating on this one?
May a thousand cranes bring blessings on you.
Johnny
I'm thinking item 72
Perhaps you are right, great teacher. But unless I know how to remove part 27, no way I can figure out if item 72 is what I need.
How is the removal done?
Johnny
Remove item 53 by removing item 54.  This gains substantial access. The rest is visually discernible.
