Kenmore Series 80 110.92584100 Motor shuts off and on
#1
Posted 07 June 2007 - 12:15 PM
Water fills up fine, but agitation, spinning, and draining, the motor runs for a little while (maybe 30 secs), then shuts off for a while, repeat. Any ideas?
thanks for any help
Billy B.
#2
Posted 07 June 2007 - 02:43 PM
thanks.
#3
Posted 08 June 2007 - 12:24 AM
#4
Posted 08 June 2007 - 01:34 AM
#5
Posted 08 June 2007 - 01:51 AM
Meter help here.
#6
Posted 08 June 2007 - 02:52 AM
#7
Posted 08 June 2007 - 02:54 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#8
Posted 08 June 2007 - 03:00 AM
If the capacitor were bad seems like you would be having the same problems in spin....but if you do replace the motor I would replace it with a new capacitor....just be sure you are getting the same voltage to the start windings in agitate as you are in spin...if not, motor is not the problem. Sounds like you are not getting proper voltage in agitate, trace back from the motor to the timer for proper voltage as the samurai suggested..
#9
Posted 08 June 2007 - 11:32 AM
Reopened unit. Ohm'ed motor, all checks out good.
Coupler was somewhat messed up, replaced that too. When motor stops, verified that 125V was going to motor from the timer.
Tested new motor, got the same problem. Agitates for about 15 seconds, then goes offline (thermal switch). Could it be something in the transmission? It seemed tight when I took the motor off the first time and turned it ccw by hand. Now, after pulling off the new motor (to take it back to the store) turning it ccw by hand seems fine and turns the agitator.
Update again... Took the pump off it seems to take a lot of effort to turn the pump using my finger. Weird thing is that it drains the water fine.
Any ideas? Thanks.
Billy
#10
Posted 09 June 2007 - 04:10 AM
But, a new diagnostic finding.....
Agitate oddly works ok and doesn't stop motor when set to FAST. When spin is also set to FAST, it doesn't spin or drain water.
"Hang Dry" mode quasi works. Doesn't drain water though (agiatate is FAST and spin is SLOW).
What is the cause of this? Do I need a new tranny? Weird problem. Any tips? Good thing this unit is so easy to work on. Gotta really give "props" to the designers of the Whirlpool/Kenmore direct drive unit.
thanks.
Barty
#11
Posted 09 June 2007 - 04:29 AM
#12
Posted 09 June 2007 - 05:26 AM
Is there any other mechanical part that hooks to the transmission that could be causing this? Perhaps the brake? As I said above, after the motor stops, I test at the motor wiring harness for voltage. Orange/White shows 125V, Blue/White shows nothing during spin. If switch was faulty, wouldn't I get voltage on both?
#13
Posted 09 June 2007 - 09:44 AM
I understand the problem is in agaitate not spin???
#14
Posted 09 June 2007 - 09:48 AM
#15
Posted 10 June 2007 - 01:46 PM
Thanks for the advice. I shorted the tan and violet wires on the water level switch so it didn't fill it up with water. PRO tip. take a small piece of 120V 12 AWG wire, stip both ends and push it in to the tan wire and the violet wire. The machine will then go into agiate mode without filling the tub. The is on a 110.92584100 series, but I bet this wiring diagram is pretty much the same on any Kenmore direct drive unit that is 12 years old or so.
Anyway, back to the problem. Yes, to my surprise the motor shutdown even though it was not connected at all to the tranmission or pump. So it is definately electrical. Can you tell me which part or switch is causing this? Thanks.
-Barty
#16
Posted 10 June 2007 - 02:23 PM
#17
Posted 10 June 2007 - 03:38 PM
I set the timer up to do an agitate cycle, this time with the motor wiring harness disconnected. On the low agitate cycle, when I test the motor harness Orange wire and White wire I get 125V, it also shows 125V when testing the Blue wire and White wire. It seems like this is the problem as it seems to imply that both the high speed winding and low speed windings are activated. My guess would then be the timer causing the problem.
When the speed selector is set to high speed agitate, just the Blue wire is hot (125V), not the Orange. Is there anything other than the timer that could be causing this? Worth replacing the timer part or just buy a new washer.
thanks again.
-Barty
#18
Posted 10 June 2007 - 04:02 PM
#19
Posted 12 June 2007 - 04:35 AM
#20
Posted 12 June 2007 - 04:38 AM
