Kenmore Dishwasher model 363.14371790
7 replies to this topic
#1 mforgas
mforgas
  • 4 posts
Posted 26 June 2005 - 08:42 AM
I have a kenmore D/W on the blink. Model 363.14371790 (GE)  It will fill with water, hums, but won't run. When the dial is turned, I can hear the solenoids clicking at the various cycles but it will not start nor will it drain the water.  Any help would be appreciated.
#2 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 26 June 2005 - 10:39 AM
Sounds like this pump motor may be jammed, reomve the toe panel and with the power cut to the unit reach under the dishwasher and find the black metal fan blade between the motor and the pump and see if it turns, if not try to work it, turn it, may be something in the pump like a toothpick or piece of food that has it jammed.  Keep trying to turn this till it frees up.  If it will not free up or if it is already free, sounds like you would need to replace this pump/motor assy., or replace the unit.
#3 mforgas
mforgas
  • 4 posts
Posted 26 June 2005 - 06:16 PM
Your suggestion did the trick. Thanks.  The motor runs fine, but now it won't fill.  I tried filling manually, but it won't drain now either. ?? Any suggestions? Thanks.
#4 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 27 June 2005 - 08:35 AM
The fill is a seperate function, be sure the float switch bubble is down, inside of the tub, if it is stuck up, no power to the fill valve.  See if you knocked a wire off of the fill valve and the water is turned on.   No drain could be the pump out coil on the side of the pump/motor assy. not pulling the pump flapper open.   make sure a wire was not pulled off of the float switch under the tub also.  This unit is possessed!!!
#5 mforgas
mforgas
  • 4 posts
Posted 27 June 2005 - 10:50 AM
An exorcism has been performed and now all is well.  Thanks for your help.
#6 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 27 June 2005 - 10:54 AM
You are quite welcome, but please tell us what the problem was, helps us and others know what to do with a haunted unit!!  ;)
#7 mforgas
mforgas
  • 4 posts
Posted 27 June 2005 - 11:07 AM
Not sure......I checked the float, made sure it wasn't sticking, reset the machine, let it run but it still did not drain, reset it again, let it run a full cycle and presto.....works like new.  Have used it since and it works fine.
Thanks again.
#8 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 27 June 2005 - 11:24 AM
Thanks.....;)
