pzjgr
Whirlpool Defrost System Problem
4 posts in this topic
OK Sensei Samurai...heres the problem.
I have a Whirlpool Model ET8FTKXKQ 18 cu ft refirgerator, purchased new in 2002. I've never had a problem with it...until now.
I noticed that water started collecting on shelves. At first I thought it was a leaking water bottle. I cleaned it up, and continued on....then I noticed it was doing it again...so I started to investigate further. It seems that water is dripping from holes in the diffuser and cover (I am getting the part names from a parts diagram, so they should be accurate).
I am assuming it is a clogged line or something in the system, where the water is backing up, and not flowing to the drip pan.
Question is where do I start my quest for a fix...what needs to be done?
That model number is not coming up, please recheck it.  If this is an 18 cubic foot top freezer there is a service pointer about this that addresses a moisture problem.
Did not come up in the Sears data base even adding the 1 in front of the 8 since this an 18 cubic foot unit so would have to be 18 after the first 2-3 letters.
