whirlpool washer- fills only, then it's dead
12 replies to this topic
#1 Guest_Need to do Laundry-Please help_*
  • Lurking at the Threshold
Posted 11 April 2005 - 06:20 AM
Ron, I will check the water level switch tonight and take your advice. i looked at the driver coupler and it is not broken or cracked, it spins the motor axle.i checked the water level switch for continuity and is ok. i had bought a new timer switch and the machine just fills with water, no agitation or spin cycles work. tested the door switch and that works properly.cleaned contacts on motor starter switch. could it possibly be the motor. i had bought the whirlpool washing machine in 2002, it will only be 3 years now that i had the machine. the start capacitor seems to be working also. twice after waiting overnight i manually put the machine on high spin and it pumped out the residual water. it no longer does anything but fill now. would you have any other ideas as to what the problem might be. thank you
#2 Ron
Ron
    Kohai
  • 368 posts
Posted 11 April 2005 - 06:33 AM
The only other thing right at this point is to make sure that motor harness is on correct.  Give that pressure switch test just like I said and see if it agitates.  Get a piece of hose around the same size and blow into that switch...If it agitates,  it's the switch.
#3 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 11 April 2005 - 07:32 AM
Could you "bench test" the motor alone to see whether it runs or not?
The Seven
#4 Guest_Need to do laundry-please help_*
Posted 11 April 2005 - 03:26 PM
in the process of bench testing outside the washer with the harness plugged in- we found an intermittent connection in the motor plug and also one in the timer switch plug.
thank you for leading us to the problem.
considering getting a new harness.
#5 Guest_Need to do laundry-Please help_*
Posted 11 April 2005 - 03:28 PM
thank you Ron for your input and answering my post.
#6 Guest_drcoon@comcast.net_*
Posted 17 April 2005 - 05:24 AM
it is the lid switch. if it won't wash or spin or empty out. you can do two things. one is buy a new lid switch. but in time that will eventually go out on you again. Or you can hot wire the switch. find a cut the wires near the switch and connect the wires. make sure you tape them good. your washer should run like new. i work for whirlpool
#7 XNSXMANNY
XNSXMANNY
    Ikkō-ikki
  • 42 posts
Posted 17 April 2005 - 01:35 PM
if you work for whirlpool why would you be giving wrong advise like that then???????????
#8 Ron
Ron
    Kohai
  • 368 posts
Posted 17 April 2005 - 02:16 PM
I agree with you xnsxmanny,  I don't think the Whirlpool fellow thought it out too well...Ron
  • 24,228 posts
Posted 17 April 2005 - 02:59 PM
Like hell he does.  I know Whirlpool techs and they're all 1) technically very sharp and 2) literate.  This clown can't even punctuate correctly.  And a Whirlpool tech would never recommend by-passing a manufacturer's safety device that's there to keep his employer from getting their a$$ sued off by ninnies who stick their arm in a spinning washer basket.
I bet that [user=0]drcoon@comcast.net[/user] is a stolen email address.
He's outta here.  :rocketman:
#10 Guest_SassyLillBittch_*
Posted 22 April 2005 - 04:55 AM
oK.. i COULD CARE LESS where you guys work.. as long as I fix my washer I am happy. Would'nt you know it "broke down" 3 days after I bought a new dryer... ANyways, I have a Roper that fills and aggitates, but refuses to spin or drain. I hear the timer click twice then nadda after the aggitation cycle. I am trying to figure out how to determine wether its the pump(pump filter if there is one),door latch, orin the timer/motor... in the simplest and and most convienient order... Any advice on where to begin??? can I bypass the doork switch?.... Spanks... Lexi
  • 24,228 posts
Posted 22 April 2005 - 06:37 AM
Hi, Beeotch.  The problem with your washer is the lid switch.
Whip it good! :whipit:
#12 Guest_sassylilbittch_*
Posted 03 May 2005 - 05:33 AM
Wooohooo...the beotch did it... pissed off the hubby too... he couldn't even figure out how to get the casing off.... he thought the top" would just lift right off"!!!   I bipassed the doorswitch and boy the spin cycle feels great!!! oops works,,,hehehe.... I am feeling so froggy think I might fix my old dryer and refund my new one... I bipassed the thermal fuse on my crosley a yr ago.. it worked wonders... now no heat..... heater core needs replaced?   should I also replace the thermal fuse???  what do you think???  Lexi
  • 24,228 posts
Posted 03 May 2005 - 10:02 AM
Way to whup up on that puppy!  Congrats on your washer repair... and showing hubby who's on top, eh hem.
Absolutely replace the thermal fuse on your dryer.  It's good you found the problem by jumpering it out, but don't run it like that for very long because it's an important safety feature to help keep your house from burning down. Ruin your whole day, dontcha know.
