tenohio
maytage washer not spinning
13 posts in this topic
When running this maytag top load no spin after rinse.  move timer to other cycles and pumpout and spin works fine.
I did check the lid switch and it works are described.  How does one find a procedure for replacing the timer.  I have the OEM time in hand.
TENOHIO
How old is this unit and what might the MODEL# be:D:huh::rocketman:
LAT9806AAM....
Its around 6-7 years old....its been a great washer and this is its 1st problem.:D
[user=1685]tenohio[/user] wrote:
LAT9806AAM....
Push in timer knob and unscrew turning counter-clockwise, remove 1/4 inch scerws that mount the timer unplug harness and re-install, Oh I forgot tomention to remove the 1/4 inch srcews on top of the consol to gain access to controls
great thanks....:D
I will give you a status update tomorrow...:headbang: Hopefully this is not how I feel tonight doing this...
ok I have it apart but the timer will not turn counter clock wise....any suggestions
I even to the whole top out to see if there was a screw somewhere and there is not...:rocketman:Ok you forgot......
How to tell me the nob comes off with a screw driver, remove the clip the entire nob can now be removed and bingo 2 screws holding the time on....
no need to turn something count clockwise....:rocketman:
This illustrates what MasterFat was explaining.
ahh oh great one...
This was exactly what I was looking for before I got started...:party:
Got another question....
On this timer I notice my old one had the timer motor terminals in slots 4 and 8 on the black harness side and the part I orders have them in 1 and 4.
I found that the new ones motor did not work, are these terminal positions moveable or did the local maytag shop order the wrong motor.
Washer Model: LAT9806AAM Maytag Factory part timer: 22001695
Number on the sticker on the motor old: 2096720 new: 2093400
Any ideas?  I am now a timer replacement expert!!  Got the old one back in and running in about 5 min.....:rocker:
O.K. I will try to make amends. On the model number plate it says series #, is it a 10 or 15? The part # for the series 15 is 22002190. You should have bought the part here, this is the only parts company that will exchange electrical parts, hopefully the co. you bought this from will exchange the timer for you, which they should since they might have sold you the wrong part. :cool:
Well lets say when one makes a mistake (and I asked the series question of the local company) they should make amends.  If they don't I have the right part in my cart on Repair.com
Oh, the reason I didn't order the part from you is that you $15.00 higher than it was locally and that is with the shipping.  That is = to a case of Coors Light and a pizza.....
Otherwise, it has to be a series 10 since the 15 (which I have) didn't work.
No problem on the instructions... I work on programming these dang computers and they are worse than appliances.  Once I started looking I found the slot on the timer knob cover and that lead me down to the 2 screws.....Just another learning experience!!
The part might have been higher but you would have recieved the right part the first time. Coors? Is that really a beer?:gulp::gimmebeer:
So many knobs, such little time
Remember purchasing parts through the Samurai's webite helps him to bear the pain of answering all these questions:grr:
Oops guy just realized that there are 2 timers and is getting the new timer for my by Friday....:yikes:Thanks for the help...
Yes Coors is a beer, not my idea of a good one (Killians is more like it) but its cold, and is great with pizza:pint:
