keyisthekey
Kitchenaid Dishwasher KUDM01TJWH1
20 posts in this topic
    I replaced the tub gasket and heater element in this dishwasher (which also required replacing the control board). It ran perfectly for one load after the repair:D, but quit in the middle of the rinse cycle on the second load:X.
It's completely dead  :poison: - no lights, no response from the pushbuttons.
It's plugged in to a live outlet:yikes:, and closing the door switch had no effect.
Open the console back up (where you replaced the control) and gaze upon the thermal fuse... known issues with these... remove one wire and test for continuity. If it is open...
CLICK HERE
to order your replacment. Make sure to use the entire kit when installing part.
CLICK HERE
Indeed, o sublime one, it was the fuse. I have sent for a replacement. Unfortunately, I cannot use the source you recommended, because they only ship to Juneau by courier, which increases the price of parts beyond my modest means. I am forced to deal with a competitor who will make the trek to the local post office and send things to me for much lower shipping costs.
I do have a question. I assume the thermal fuse opened up because the air temperature at the door vent exceeded 98 degrees C, its rated opening value, during the drying cycle . This is evidently hotter than with the original heating element. The information sheet sent with the new element/control board indicated that the new element consumed more wattage when in air, which should result in higher temperatures during the drying cycle after the water drained out. However, when I opened the door after the fuse opened up, there was 2 inches of standing water in the bottom of the tub, completely submerging the heating element. The fuse is up by the vent at the top of the dishwasher's door. For the air passing by the thermal fuse to be hotter than 98 C, that water would have had to be boiling (100 C). That's pretty hot for dishwashing!
So, here's the question: Is replacing the thermal fuse going to solve this problem, or am I just going to blow another one out because the new heating element is too hot  for the design of my older dishwasher?
if it does it would probably be something else causing it to go.  be sure to cut and splice in wires as described replacing just the fuse will cause it to go again.  the air shouldn't be moving across the fuse .  if it is then the et seal is bad.
The failure of the thermal had alot more to do with the loose connections of the wires on the fuse itself than the temp on the new element. Loose connections produce heat, which in turn trips the fuse .This is why I recommend you use the entire repair kit , which includes new wire connections. You probably inadvertently loosened them when you changed the control. Congrats on your repair!            Sorry BLTH, you beat me to it!LOL!
Plugged in, and hooked to water and drain. Pushing any of the buttons get a light, but nothing more:poison:. The drain button works, and the unit will pump out a quart of water if you pour one in the bottom.
Not sure what to look at next:?.
any lights flashing? or just steady on?
(you should have continued with the original thread for reference)
When you replaced the Thermal Fuse, did you use the Wiring Kit that came with it ?
I merged 'em.
Clean light is flashing 7 times, pause, 7 times, pause, etc. Pushing either the high-temp or the energy save button gets two quick flashes of their respective lights. Others steady on.
Thanks for the merge.
Yes, I used the full kit to reinstall the thermistor.  It's worked fine up until about a week ago.
sounds like a problem with the heat circuit.... need to ohm out the heating element and high temp T-stat then give us a post back.
How do I find the high temperature thermostat?  What is the flash 7 times telling me?
OK, I read the service pointer, but still don't know how to run the service diagnoistic on my machine, which, an earlier post said, may solve the problem. I downloaded a sheet for the TB0, which says to press heated dry, normal, heated dry, normal within 6 seconds.  My dishwasher does not have a heated dry button. The tech spec is not inside the door where it's supposed to be - it's a used dishwasher, was probably removed by the previous owner.  What do I press to get the service diagnostic started, and how do I interpret the readout.
I'll drag the thing out from under the counter if I can't run the test, but I'd sure like to see what the machine has to say for itself before I do that.
Thanks very much for the tech paper - it's a big help. I've run the diagnostic now, and everything checks out. I now get responses to the buttons. However, the motor is not turning. The valves open, it takes in water, the pump empties it out, but when it gets to the part of the cycle where the motor is supposed to start turning, all I hear is a loud hum, and the motor gets pretty warm if I let it go for more than a few seconds. We pulled it out from under the counter, set it up on a couple of chairs, and confirmed that the motor is not turning over. So, what's the usual failure mode? Motor, starting capacitor, or some other component up the line?
No, cannot turn it by hand. How do I get to the chopper blade?
BTW, the motor ohms out correctly (7.8 ohms across the main winding, 5.6 across the auxiliary), and the capacitor charges and discharges nicely. Also, in response to the first suggestion, I did measure the resistance of the heating element (13.8 ohms) and the hi-temp thermostat (0.9 ohms).
Found the procedure on the chopper blade. Doing it now.
Removed chopper assembly and cleaned out a few bones and a piece of plastic that looks like half of one of those anchors you push into a wall to hold a screw. Reassembled, tried to run the dishwasher, but motor still not turning. I suspect the other half of the plastic thingy might have made it past the chopper and gotten into the motor, or perhaps something else is jamming it, or the bearings are shot, because it's really trying to turn. I'll try removing the motor the next time I can get to this project.
