whirlpool chain of problems...
#1
Posted 11 April 2005 - 11:07 AM
here are some observations:
- the whole basket seems to be sitting low, but it still self-centers. like, the gap between the bottom of the agitator and the innerbasket has gotten greater.
- i took off the agitator to look at the drive block, and it was coated with metal shavings and a lubricant. i'm not sure if the metal shavings are normal? the plastic spacer thing as well as the metal clip that are on top of the spanner nut are in fine condition.
I can take out the drive coupling or the drive block to look for damage, but i don't know what to look for. is there anything else that could be causing this, besides those two pieces?
Is this two different problems, or the same one?
Thanks!
#2
Posted 11 April 2005 - 11:54 AM
See if those notches are worn. Metal filings under the agitator are usually a sign of a deteriorating drive block.
#3
Posted 11 April 2005 - 12:12 PM
Thanks so much for your help!
i put in a poor pic, i'm not sure if you can see what i'm talking about or not. or so i have to take off that special nut to see the piece totally?
#4
Posted 11 April 2005 - 12:13 PM
#5
Posted 11 April 2005 - 02:04 PM
#6
Posted 11 April 2005 - 02:49 PM
#7
Posted 12 April 2005 - 01:19 AM
Those two tabs that stick up and are bent in towards the agitator shaft. They need to be bent back out to the correct position or a new drive block is just going to strip out in no time at all.
Take a small square ended chisel and gently tap it with a hammer in between the agitator shaft and the tab at all four cornes of the tabs.
Use the new drive block turned upside down to gauge when you have them back out to the correct position, if you go to far you won't get the new drive block to seat down correctly.
This is what I do anytime I replace a drive block on these newer Whirlpools that seem to be having this problem. I haven't had to go back on one yet and didn't have to charge the customer for a new spin tube/brake assembly replacement either.
William Burk (Willie)
Eureka, CA 95501
Eureka, CA 95501
#8
Posted 14 April 2005 - 12:06 PM
the drive block currently in there does not look worn ( i had to remove the inner basket to see) and it looks different than the part i ordered. i checked the model number with the folks at repair clinic. my drive block does not have those two notches on the inside. ??? it was the only whirlpool drive block i found.
also, i've removed the inner basket (the pictures i sent were before i did that and you could only see the top of the drive block. but, i can't get the damn drive block out, i've tapped up on it like crazy, still it won't budge. any suggestions?
PS: while i'm at it should i clean out all that sludge in the bottom of the outer basket?
thanks folks for all your help.
i'm putting a pic of my washers innards here and in a reply to this post.
tripp
#9
Posted 14 April 2005 - 12:07 PM
#10
Posted 14 April 2005 - 12:13 PM
#11
Posted 14 April 2005 - 05:49 PM
#12
Posted 15 April 2005 - 12:31 AM
Also check the outer plastic tub and make sure none of the gouges in the bottom go all the way through, I can see signs of where you spin basket rubbed pretty heavily on the bottom of the outer tub.
Eureka, CA 95501
Eureka, CA 95501
#13
Posted 21 May 2005 - 02:16 AM
Kevin
#14
Posted 21 May 2005 - 03:21 AM
Also, you don't need to remove the tub to see if the drive block is bad. Look at the picture posted above and if yours looks like the picture then the drive block isn't your problem. Notice the two tabs that are level with the top of the drive block, that is what your looking for. If your drive block is bad the spin tube, which has the two tabs sticking up , will be sticking about a 1/2" to 1" above the top of the drive block.
Eureka, CA 95501
#15
Posted 21 May 2005 - 10:28 AM
Thank you. I feel your site is great. I was wondering what kind of delivery time you have on your parts to the Houston, Texas area?
#16
Posted 11 May 2008 - 12:24 AM
Samurai - Your http://www.repaircli...?R=154&N=389140 link is bad in this http://applianceguru..._id=736"e=1 ]Post[/url].
Here's the right one:
http://www.repairclinic.com/referral.asp?R=154&N=389140
Also, your "Help" page (the button at the top right of this page) says to use the above format for links, but as you can see, it doesn't seem to work!
[/color]
#17
Posted 11 May 2008 - 12:33 AM
]]Drive Block.
dont use " " on the URL, you can use them on the "Drive Block" if wanted.
#18
Posted 11 May 2008 - 09:58 PM
So once you've done something, you can't access the raw code again to make any adjustments you might want to make, because it's already been converted into the resulting effect right there in the editor display. I thought that's what the Preview button was used for.
#19
Posted 12 May 2008 - 12:12 AM
#20
Posted 12 May 2008 - 04:13 AM
musical chairs ?Here's the right one:
they just changed it again
now it's a another different part number
RepairClinic keeps changing their part numbers ?
NOW it's http://www.repaircli...R=154&N=1021707
