new build problem with cd-rom
2 replies to this topic
#1 beagle
beagle
    IkkĊ-ikki
  • 42 posts
Posted 26 August 2007 - 04:57 AM
We're building another computer(we've done this before).  Started WindowsME from A drive boot up.  Then installed from Update disk in CD-ROM(D drive).  Runs okay at this point.  Got a new sound card to install, placed disk into CD-ROM and discovered the system will no longer recoginize the D drive.  We have three CD-ROM and DVD-ROMs(all manufactured after 2000) and have tried several configurations.  The BIOS lists a Primary IDE master and slave CD/DVD ROM devices and the S-ATA hard drive(new purchase).  Any ideas would be greatly appreciated.
#2 mike35z
mike35z
  • 4 posts
Posted 26 August 2007 - 10:15 AM
If you are booting off of the serial ata drive...make sure it has the jumper setting on the drive...in the master location.  The other drives can be configured with the jumper settings in the cable select mode.  The serial ata might be causing a confliction if your using windows ME.  Make sure you have downloaded all the updates from microsoft..and see if that will solve the problem.  Also make sure you loaded all the drivers for your motherboard that came with it.  They are usually on a cd rom disk.  Check your system bios to make sure it is set up for "Boot from ATA serial drive", if this is an option in the bios setup.
Hope this helps
Mike M
A+ certified tech
#3 rvmessina
rvmessina
  • 12 posts
Posted 30 January 2009 - 08:21 PM
Please do yourself a favor, at least upgrade to W2K if you can find a CD for it.  WinME is one of the worst products designed by MicroSoft.  At least you will have plug and play with W2K..
If you do not want to do that, make sure your I/O jumpers are such that you do not use an address that is in use already.  That will cause the device not to be reconized.
Good Luck..
____________________________________
Save the environment, plant a Tree!!
