ICEMAKER ISSUES AND I HAVE BEEN DOING REPAIRS 9 YEAR HELP
7 replies to this topic
#1 jagrider91
jagrider91
    Ikkō-ikki
  • 22 posts
Posted 29 August 2007 - 03:41 PM
  I INSTALL A NEW ELECTRONIC ICE MAKER IN A CUSTOMERS BOTTOM MOUNT GE REFRIGERATOR AND HE SAYS STILL NO ICE.  ALSO REPLACED FILL VALVE. PLEASE HELP.
#2 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,215 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 16 September 2007 - 02:50 PM
is the fridge on the outlet side of a reverse osmosis or plugged inline water filter? r/o filters drop the water pressure enough in some cases that the water valve will not allow water to pass
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#3 jagrider91
jagrider91
    Ikkō-ikki
  • 22 posts
Posted 17 September 2007 - 12:58 AM
what is reversr osmois
#4 BrntToast
BrntToast
  • 1,215 posts
Posted 19 September 2007 - 02:43 PM
reverse osmosis is a fancy water purification filter, usually under the sink(same place fridge water comes from quite often) or the r/o filter could be in the basement as well
trace fridge water line back to main water source and make sure there are no filters, if there are bypass said filter if possible
also very low water pressures from houses that have wells or extremely high water pressures(only ever seen this once in a high rise 1 floor above their second booster pump) will cause valves to not open
#5 himeros
himeros
    Kohai
  • 312 posts
Posted 09 November 2007 - 12:29 PM
Take one of your ac cords that have an icemaker connector on it, plug that onto the icemaker valve for 5 seconds, and see if the maker fills up with water that way.  Sometimes the fill spout in the freezer will freeze up and not allow water to enter the maker.  Good luck.
Himeros
#6 TOPPS Appliance Service
    Ikkō-ikki
  • Master Appliantologist
  • 32 posts
Posted 30 August 2008 - 12:43 AM
I always start with the simplest, and check the supply line tap. I've seen this numerous times were deposits block flow.
Toledo's "TOPP" Choice
www.TOPPSappliance-service.com
#7 RegUS_PatOff
  • 30,299 posts
Posted 30 August 2008 - 01:55 AM
especially if they're using a "self-tapping" saddle valve.
Better to use the type that needs to have the tap hole drilled...
#8 ROBBYRIG
ROBBYRIG
    Senpai
  • PipPipPipPip
  • 635 posts
Posted 30 August 2008 - 11:24 PM
I agree with Reg.  But if you do run into one of those, you can pull the needle part out of the "T" and snap it off with your pliers.  I've found that this sometimes allows more flow.
