LG LFC25760--It's snowing in the freezer drawer
3 replies to this topic
#1 OAR
OAR
    Yamabushi
  • Scholar of Appliantology
  • 87 posts
Posted 31 August 2007 - 07:44 AM
humble apprentice seeks wisdom of LG master..:yikes:
Second time this week I've run into this problem. Frosty ice build up inside freezer drawer of LG LFC2560 mod. (french door type with freezer on bottom)..not like a defrost issue...frost is accumalating all over the front of the top basket as well as other places you would not expect to see..as if moister is being shot in by some mystious source...drawer gasket looks fine..pass on the dollar bill test...don't believe ice maker is culprit either....suspect semi frozzen H2O is being tossed into freezer by evap fan in the back (perhaps during/after defrost) but not sure how to confirm...or...deny???
Please Help!!!!
Famous last words:....Hey dude! Hold my beer and watch THIS!!!!!
#2 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 31 August 2007 - 08:22 AM
Remove all of the frost from the freezer, remove the flap on the end of the drain tube in the rear, take a 1 inch pvc cap and fill it with water and put the end of the defrost drain tube into the water....the warm moist air in the kitchen will not get sucked into the freezer now when that fan is running....;)
#3 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 31 August 2007 - 08:24 AM
If that does not solve the problem then would need to change the motherboard since it has updated software to address this frost.
#4 OAR
OAR
    Yamabushi
  • 87 posts
Posted 31 August 2007 - 08:39 AM
Thanks Pegi, I'll give that a try!!!:cool:
