Sub-Zero Refrigerator - Model 650/S - SN M1551539 - IceMaker Inoperable
#1
Posted 31 August 2007 - 10:30 AM
Control panel inside refrigerator indicates Ice on/off is ON. Water is connected to selonoid valve as I have tested it with direct current and it pumped water.
Not sure how to troubleshoot this further or if I need to call out Subzero repair:yikes:.
#2
Posted 31 August 2007 - 11:36 PM
http://www.fixitnow.com/beerfund.htm
#3
Posted 01 September 2007 - 01:32 AM
Also, the inlet tube is warm so it looks like it would not be frozen. One other clue (may or may not be relevant), the problem started when the "sealed system" failed back in April '07. Had Subzero replace the sealed system/condensor at that time, but the icemaker no longer worked. It worked up until the time the sealed system failed.
#4
Posted 01 September 2007 - 08:54 AM
#5
Posted 03 September 2007 - 04:34 AM
Thanks for your help.
#6
Posted 04 September 2007 - 12:43 AM
Through the diagnostic, found that the motor is cooked. Will order a new i/m and provide the results.
#7
After further testing using ACMEHOWTO.COM diagnostics, determined that it was the thermal cut off. Found a broken lot I/M replacement with a somewhat different wiring harness on ebay for $20 and used the thermal cut out to replace the fried one on my current icemaker. Things are working just fine now.
