BHC
Fisher and Paykel MW511 Washing machine
11 posts in this topic
Hi all.
Hoping someone here can help me out...
Last night  sometime my machine started beeping every second, the third and fourth lights in the wash progress indicators are on, as well as the spin cycle light. The machine will not function at all - it just keeps beeping at me. I have tried turning off at the wall for a few minutes with no joy.
It's kind of got me flummoxed as the machine was not in use at the time, it has just happened out of the blue.
Any thoughts would be appreciated.
Cheers
BHC
It sounds to me like one of the inlet valves/water solenoids is faulty.  Remove the lid and top console and check the inlet valves with a multimeter, they should read about 65 ohms.  If this is not do-able, then press and hold wash temp down button, then press power, and then release both.  Press the wash temp up button, the hot valve should let water into the W/M ( assuming you have water coming out the W/M end of the hoses ) , now try wash temp down, the cold valve should come on.  Whichever one doesnt let water in, is faulty, and I suspect , with the light display it is the cold valve.
Hope this helps;).
Hi Kiwi, thanks for the reply.
I am about to leave for a week of gem fossicking, so will try it when I get back and let you know how it goes.
Cheers
BHC
Gday Kiwi.
Got home a few days early.
OK I checked the ohms and got 60.8 for the cold and 61.5 for the hot.
I tried the other test and got no water from either - the test may be unreliable because as soon as there is power to the machine it starts beeping, and when I press buttons it just keeps beeping - so I turn off the power at the wall hold the temp down button switch on the power socket and then press the power button, this gives me the following light pattern (see image) after which I did the test and no water flowed from either inlet.
Any ideas?
Cheers
BHC
Edit: If you want any more pics with what lights are showing let me know.
The resistances for the valves look ok.  You could try turning power off, and remove all plgs and then refit and try again.  Was it doing the beeping thing before hand?  and when you first turn on the power which lights come on?
Hi again Kiwi.
OK have removed all electrical plugs I can access and re-attached, have removed hoses from machine and re-attached, have unplugged plug from wall for a few minutes - no joy with any of these.
Yes it was beeping from the start, once every second.
Have attached a pic of what lights come on when the machine is switched on at the wall.
Thanks for the help. Cheers
BHC
The lights indicate the cold valve is faulty, but the the resistance says otherwise.  You could swap the hot and cold valve plugs over and see if this makes a difference.  If the valve is faulty then the lights should change to 0 0 1 1 0 0 1 0.  The only other thing that could be a fault is the control board which is likely due to the correct resistance readings - MC P/n 420376p.
I tried switching the valves over and got the same light indicators.
When you say the control board - do you mean the motor controller or something else?
Cheers
BHC
Yes, the motor controller.  It has so many different names depending on where you live.  I am almost positive that this is the problem.:(
Gday Kiwi.
I bought a new motor controller and installed it today, cost me $195 (gulp) - just doing a load of washing now, everything seems to be running fine.
Thanks very much for all your help, I really appreciate it.
Cheers
BHC
No worries;).
