Kenmore 362.75501990
#1
Posted 16 September 2007 - 04:01 PM
#2
Posted 17 September 2007 - 02:26 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 17 September 2007 - 11:59 AM
#4
Posted 17 September 2007 - 12:13 PM
#5
Posted 19 September 2007 - 03:23 PM
Thank you
#6
Posted 19 September 2007 - 04:13 PM
we might to be able to find some info if you open the back panel and give us the part number off the control, number will be something like wb24m36(made that up but it gives you an idea which number to look for)
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#7
Posted 20 September 2007 - 02:16 PM
#8
Posted 20 September 2007 - 02:17 PM
#9
Posted 20 September 2007 - 02:59 PM
as per your earlier post, this difficulty is not cause its a GE its cause its a kenmore.... they guard manuals and parts lists so consumers are forced to use their service
now even if your control was switched to celcius, that 280C would be one hot oven and yours is not
from what i have found yours is a gas oven, correct? can you tell if the burner is lighting, the oven bottom should be removable to watch for flame... your might have no flame and just an igntor warming the oven slightly, but i would think you could still set the control higher
#10
Posted 20 September 2007 - 03:19 PM
Yes it is a gas oven. I removed the bottom and did watch the flame light. It took a minute or so, but it did light. I turned the knob high and low but the flame didn't change, but I don't know if it would since it wasn't pre-heated. My wife just cooked some bisciuts in it and at 280, which the oven said it was pre-heated to, and it took about 30 minutes, so it is not getting hot. The stove part works fine, it lights and adjusts just like it always has.
btw its funny that you say GE is not the problem, because my dad fixes X-ray equipment and they have the same problem with GE hiding stuff from them.
Thanks for your help.
#11
Posted 20 September 2007 - 03:31 PM
did you notice if the flame cycled on and off during the baking or did it burn the entire 20 minutes?
#12
Posted 20 September 2007 - 03:42 PM
#13
Posted 20 September 2007 - 03:48 PM
from what you have said so far i'd say you need that electronic oven control
the samurai has a link on the form for a parts supplier that allows you to return parts for any reason so on the off chance it doesn't fix your prob it can be returned
#14
Posted 20 September 2007 - 04:02 PM
http://www.repaircli...xt=`NWB11K10012
#15
Posted 20 September 2007 - 04:12 PM
#16
Posted 20 September 2007 - 04:13 PM
#17
Posted 20 September 2007 - 04:37 PM
#18
Posted 21 September 2007 - 12:37 PM
#19
Posted 22 October 2007 - 02:15 PM
#20
Posted 30 October 2007 - 03:49 PM
