Dishwasher Installation
4 replies to this topic
#1 mkropp
mkropp
  • 8 posts
Posted 11 April 2005 - 12:34 PM
We are redoing our kitchen and want to move the dishwasher farther away from the sink than the drain hose will reach.  We can install a new drain just for the dishwasher but I don't know if there are any problems with doing this.  Can this be done?
--Mike
  • 24,296 posts
Posted 11 April 2005 - 04:13 PM
No problem doing it, I see it all the time up here. Most local plumbing codes require an air gap but if it's your own house you can do whatever you want.
#3 mkropp
mkropp
  • 8 posts
Posted 12 April 2005 - 01:57 AM
OK, thanks.   Do I just run the drain line into a separate trap with the sink end capped off?
--Mike
  • 24,296 posts
Posted 12 April 2005 - 04:42 PM
Into its own trap, yes. Usually this ties into the sink main drain. Not sure what you mean by capping off the sink end.
#5 The Wizard Of Odds!
The Wizard Of Odds!
    Ikkō-ikki
  • Master Appliantologist
  • 21 posts
Posted 22 April 2005 - 11:13 PM
Just use rigid enough drain hose so it doesn't kink when you put the hose up and back down again to create the anti siphon "air gap"
If it kinks it won't drain out.
O K ?
