  • Announcements
MSchett2
Water Dispenser not working
5 posts in this topic
The water dispenser on my KitchenAid KSBS20Q refridgerator has stopped working. It was working sporatically, but has now stopped. It was taking about 10 seconds to start then would work after a second or two, but again now it doesn't work. The ice maker is working and gets water. I checked the switch and it is getting power and has connectivity when closed. It is a double switch and the light is working so I know it is being depressed. I am thinking it is the solinoid. It must have a double so the ice maker is getting water and the water dispenser one is stuck and not working. Am I right? Are there more things I should check? The water flow was good when it was working and the ice maker gets water so I don't think it is the line. I don't appear to have a filter (at least I haven't found one) so that can't be clogged.
Sounds like a fill valve going bad on the dispenser side.  If it had a filter it would feed both sides. Unless the water line is freezing up to the disp.
To test it I thought I could go to the resevoir inside the fridge.  If I disconnect the lines I could see if water was coming in past the valve.  If that works I could check for a clog from the resevoir to the dispenser.
To make it easy make you a test cord and go right to the disp side of the fill valve to see if you get water going direct to the valve.  You could also have a broken wire in the door or where the harness goes thru the door hinge also.
