GE Profile Harmony Washer WPGT9350C0PL won't turn on...UGH!
16 replies to this topic
#1 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 18 October 2007 - 07:31 AM
Ok, it's about 5 years old, model as listed, S/N MF400288M. It had been giving an error message (which I can't recall at the moment) and could get past that by resetting but it died between loads this morning. I wasn't able to get any response from the machine when I attempted to turn it on via the LED/Front panel buttons.(It's actually my neighbor's machine and I'm helping repair) I removed the PBA/Main Board and there's a place where part of a circuit seems to have gone bad (the black material under the screw has broken off) but they really did a number on self/user repair with coating this with gel after putting in the tray base.  The circuit looks like #IC300, being in the lower right corner, just under the transformer. Part of the black material has cracked off and is usually screwed down. Would I be correct that the whole problem is with the board? I couldn't get any response from the machine when I plugged/unplugged and the LED won't light up. Suggestions? THANKS for helping!;)
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 18 October 2007 - 01:10 PM
most likey you have found the problem, a picture would be great
#3 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 18 October 2007 - 02:48 PM
I actually found the board, a new one, on Ebay for a ton less than anywhere else and have ordered it. Hope that solves the issue. THANKS!:cool:
#4 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 24 October 2007 - 12:01 PM
Ok, got the board installed and NOW :yikes: the diagnostics come up with two other messages:
1) Motor is not rotating properly and 2) serial communication between washer & dryer is down.
I can handle the issue with the cable...might be that when it was getting moved, the end was pulled out of the dryer serial cable and will need to replace that. What I CAN'T figure out is the part that will remedy the situation........
THANKS!
#5 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 25 October 2007 - 10:51 AM
double check your connections at the board as well as at the motor
#6 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 25 October 2007 - 11:16 AM
Will do. Thanks!;)
#7 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 25 October 2007 - 01:15 PM
my pleasure
#8 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 03 November 2007 - 03:45 PM
Got the motor installed and all went well, on the first load. Now it won't drain?????:yikes:
#9 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 04 November 2007 - 12:58 AM
Check to make sure that you are getting voltage to the water pump, if so take the hoses off and pull what ever is in there out
#10 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 04 November 2007 - 01:47 AM
Will give that a try.
THANKS! :)
#11 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 05 November 2007 - 09:05 AM
Well, I tested the machine and, as normally happens, it worked fine. Go figure!
#12 jambatt
jambatt
    Senpai
  • PipPipPipPip
  • 905 posts
Posted 05 November 2007 - 12:24 PM
#340 Coupling Assembly WH01X10210
#345 Coupling                 WH01X10211
Don't take life too seriously, none of us get out alive !
#13 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 05 November 2007 - 02:12 PM
#14 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 12 November 2007 - 06:21 AM
Ok, after about 5 loads, the Main Board has blown again.
#15 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 12 November 2007 - 06:23 AM
No need to worry about the photo....solved it myself.
#16 TLC917
TLC917
    Ikkō-ikki
  • 43 posts
Posted 16 November 2007 - 02:11 PM
Think I found the problem, thanks to all those that tried to help.
#17 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 16 November 2007 - 02:15 PM
what did you find?
