bostoncraig
DishDrawer DD603 - LCD "randomly" flashing numbers and symbols
2 posts in this topic
I think I mistakenly entered this "mode" by holding the ECO and Power buttons for 5 seconds. Pressing power is the only way to stop the light show, but then the wash cycle is set to 5 minutes and I can't seem to change it. Running it for 5 minutes didn't seem to help. It stops without draining and the lightshow continues.
I don't think there's a hardware problem. I think I just screwed up and I'd like to reset everything back to the way it was.
BTW, in my efforts to fix this problem, I did manage to make it play some music.
Thanks in advance.
Although I never saw a proper fault code, instructions for clearing a "stuck" fault code include turning off power at the source. So, I figured I might as well try that.
Cycling the power appeared to reset things properly and I was able to start a normal wash cycle. I'm assuming it will run to completion just fine.
