GarretV
Whirpool dishwasher noise
8 posts in this topic
Whirlpool Dishwasher   Model# GU1200XTKB0   Year: 2002
When I start the washing cycle the unit seems to fill with water normally. But when the next stage begins it sounds like someone has turned on a wood chipper in my kitchen! I'm assuming its in the pump or motor. I'm not sure if the water is spraying inside the unit as the noise it is making is too loud to hear the water.
Where should I start?
You probably got a piece of glass or plastic stuck down in the impeller.  Take off the spray arm and work your way down to the impeller so you can clear the object.
Ok, I'm probably going about this the hard way but, I've taken the dishwasher out and apart.
I now have the whole pump/motor assembly on the kitchen counter. I have the motor loose but can't seem to get it free from the housing. The impeller area has a plastic cover that seems to have only one screw attaching it. I've got the screw off but can't get the cover off. I'll attach a picture. What's holding this cover in place? (see the lower right quadrant of the housing.)
Spoke too soon. I've got the cover off and the motor out. Ok, I did find some glass in the impeller area! I don't see anything else visually that could be wrong, so I guess I'll put this thing back together and see how it goes...
The impeller and the chopper are connected with a notched/spring loaded connection. Because of the glass jammed in the chopper, the notches have been worn away. It looks like I need to replace both the impeller and the chopper. How do I get the impeller off the motor? Is it a press fit on the shaft?
Thanks.
Ah, grasshopper, you have done well and your initiative has earned my special attention.  Enter the joy of thy master.
Your photo reveals much about your dishwasher-- I wish more folks would take advantage of the attachment feature.
Yes, the cover to the mascerator can be stubborn, but you persevered and prevailed.  Nicely done.  Here's what I would do at this point:
These motors are bad for burning out at the first sign of trouble.  So, there's a 50-50 chance that the motor is either dead or will die soon.  The entire motor/pump assembly in your dishwasher has a 5 year warranty.  Whirlpool is a company who is easy to deal with on these matters.  Ass-u-me-ing that your d/w is less than 5 years old, call Whirlpool and have them send you a replacement pump/motor assembly (that's essentially the entire thing shown in your photo, plus the pump and motor, not shown).
If your d/w is older than 5 years old, let me know and we'll talk more about the ancient art of Fixite Do
Sears won't but if the dishwasher is branded Whirlpool (the actual manufacturer of this dishwasher) or Kitchenaid, it's warrantied for 5 years. And they send the motor/pump assembly right out, no hassles, no fuss.
What you're dealing with is the way Sears has chosen to handle the warranty.
