Learn how to be your own tech line…
sjhoffman
Broken Dishwasher full of dishes
16 posts in this topic
I have a big problem.  I have read over 100 different posts that are similar to mine but I still think that mine is unique.  My dishwasher thinks it's working but it's not.  When you start any of the normal wash cycles it says that it's sensing the load and it begins to fill.  When it says that it is going to start washing, instead it drains and then continues through a normal wash cycle.  Its pausing the whole time (to heat the water thats not in there) then it flips the soap door on que and soon enough says that it's finished.  When the washer first says that it's beginning to wash is when the motor usually engages it's not anymore( that's when it drains the water)  Also it doesn't seem that its filling to the correct height.  I've checked the float and it seems to be operating clean and free.  So... is it the switch, the valve or the motor?  I've also reset the breaker box on 2 seperate occasions.  Thankyou for any info at all this is all new to me.
I would check your drain connection, sounds like you are loosing the water charge. Try installing a "siphon break" to your drain hose, make shure you mount it according to the instructions.
Other than that, we need more info
sorry it took so long to get back to you....Iwas out of town.  I don't understand how it could need a siphon break when it was working fine one day, and then broke the next...??????
What's the brand and model number?
I'm so sorry I thought it was in my post,  it's a Kenmore 665.16872000
I am eyeballs-on-it positive that the basin is filling, I am also positive that it is draining just fine except for more gunk than I would like where it connects to the garbage disposal.  However, recently, when I was still trying to trouble shoot the problem, I noticed that the motor was trying to run but just had a low hum coming from it.  I had a friend come over, explained the problem, so he tested the motor.  He said that the motor is shot and needs to be replaced.  Where do I go now???
P.S. I Hope that thirty dollars can buy you a few more 12-packs...Grasshopper...
Remove the dirty dishes and wash them by hand then replace the motor or the dishwasher, would seem like makes sense. ;)
The dirty dishes are already done.  It only seemed like the next best thing to do.  I only hope( samurai, that this is enough for beer from a grasshopper, if not let me know: )  Should I replace the motor or buy a new dishwasher???
I won't tell you what you should do.  But I will give you some heuristics for your grist mill:
1.  All dishwashers today suck.  All.  Period.
2. On today's appliances, the industry average is that you'll be doing some type of repair on a new appliance every two to four years.  The only question is the difficulty and expense of those repairs.  See rule number one for dishwashers.
That was the best .... You almost made me spit my beer out   LMFAO
Based on your first post I suspect that if you replace the motor/pump you will still have problems that require you to sink more $ into it.  If it were me I would replace it.
My  6 year old Jenn-air dishwasher motor crapped out on me recently.  Apperently the level switch didn't work causing the tub to overfill, leaked onto the motor causing the motor drain windings to melt and got the control circuit board wet which caused strange problems.
After I dried off the control circuit board I confirmed that the drain motor windings were shot.  After researching a replacement motor I discovered that they come packaged with the pump.  My guess is they package these together because if the pump seal leaks water will drip on the motor windings and cause the motor to fry.
I decided not to drop $200 into a 6 year old dishwasher that was showing signs of wear.  I ended up spending $500 for a new dishwasher with a tall tub design and a stainless steel tub.  I like the tall tub design, I can put cookie sheets in the dishwasher now.
Since I have 5 people in my family and we do an average of two loads of dishes per day, I did not want to get the bottom of the line dishwasher.
Thanks for the info, Southern it makes sense. Thanks for everybodys input on this problem of mine.  Truthfully I am only a renter but I have complete control in matters like this.  I spoke with the landlord and they seemed to think it best to replace it based on everyone's info.  It seems to me that if every dishwasher is crap on the market today, why not just buy an extended service warrantee like most places offer, and than let them fix it in 2-4.   Does this make sense ?
P.S. everybody that frequents this web site really should contribute to the  United Samurai Beer Fund because there are alot of websites out there like this that DO charge for this info and it's not as reliable as these Master Appliantologists.
Extended service contract only make sense if you are not capable of servicing you own appliances.  They also tend to be set-up so that they are out of warranty by the time you have any problems.
In my situation I did not have any problems with my dishwasher for the first 6 years.  If I purchased an extended service contract for 4 years then I would have wasted my $.
Used to did not need any extended warranty as things were well built, but with all of the new stuff out there today I tell everyone to buy the extended warranties for as long as they will allow, you will need it...I buy them now for everything.  ;)
