dual wall mount oven with f2 code
3 replies to this topic
#1 Guest_luvmynad_*
Guest_luvmynad_*
  • Lurking at the Threshold
Posted 30 March 2005 - 01:49 PM
i have a dual wall mounted GE oven with the top oven displaying a f2 code after using the self cleaning mode.  so i used the bottom oven to cook with but now after cooking the lower oven displays the same f2.  it was installed in a new house in 97.  i'm at work and dont have access to the model number right now.  oh by the way its beeping everytime it displays the f2 code.  any help would be great.
#2 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 30 March 2005 - 03:25 PM
   The force is telling my your cooling fan is not working properly.  Turn off the breaker.  open the console.  Look at the fan,  try to turn it with your finger.
   Sometimes the fan blade will slide up the shaft and hit the screen and stop spinning.  Does the screen have fine mesh? if so, is it dirty?
   Read the tech sheet taped to the left wall.  Find and bypass your "fan thermal switch".  Then turn the breaker back on. Does the fan run when you do that?
  • 24,218 posts
Posted 30 March 2005 - 05:02 PM
Do like the Jedi says. If you need further information, click here.
#4 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 30 March 2005 - 10:20 PM
It appears that some ovens with ERC (electronic range control) will most likely to have some problems after self-clean cycle. These ovens use mainly oven temperature sensors.
Some of the following information from some web-sites could give us some insight "why":
(1) The temperature of the oven is very high (about 850 deg F (450 deg C)) during the self-clean cycle.
(2) The operating temperature range for NTC thermistors is from -100°C to + 300°C.
(3) Metal RTD's (Resistance Thermometer Device) offer a wide temperature range from -260°C to +850°C. But Metal RTD's are more fragile than NTC thermistors.
My comments:
If they use NTC thermistors as oven temperature sensors, the high temperture during self-clean cycle will easily damage the thermistor-type sensors.
If they use Metal RTD's (as most are), they could stand the high temperture. However, Metal RTD's are very fragile because they are constructed with fine wire to obtain about 1000 ohm at 70 deg F. The expansion and contraction due to large temperature change (from 70 to 850 deg F) could break (or short-circuit) the fine wire.
The Seven
