Learn how to be your own tech line…
RodG
Looking for a Low pressure icemaker
8 posts in this topic
Hi,
I am wondering if anyone makes a low pressure icemaker. I would like to run one off of my reverse osmosis system, but the presure is only about 7psi. Anyone know of anything?
Rod
The pressure requirement is based on the needs of the water inlet valve, not the icemaker. Theoretically, you should be able to find a low pressure solenoid valve, though I have no idea where. But then, that's why the pot-bellied Buddha gave us Google.
BTW, I supply RO water to my icemaker, no problems other than the occasional batch of hollow cubes.
i believe they sell "low pressure" ice cubes at most gas stations,they come in a 5lb. bag.
Thanks for the replies. I knew about the 5lbs of low pressure ice cubes. lol   I'll try installing the icemaker and see if I can make it work.
Rod
Cute Kdog, but do not think that is what he is looking for.  LOL    I believe there is some sort of system that can be installed to boost the water pressure to the ref., but do not know how they work, nor where they can be obtained, probably like some sort of holding tank that is pressurized.  I have seen references to this sort of system for dishwashers when low water pressure is an issue as most are time fill also.  With low water pressure you will have problems with enough water to fill the ice maker, small cubes and the thru tube freezing up perhaps.  Or it sticking open, flooding the box.  Turn the fill time up on the ice maker so more water will enter when it calls for water.  Other than all of this do not think can do more about this as should be 20 psi to the valve for it all to work properly.
Hi Pegi,
I have found a booster pump, but it doubles the cost of the setup. I was just trying to find a cheaper way to get it done. The icemaker is 149 and the booster pump was 180. CND.
Rod
Rod, looks like we did not ask if this is an ice maker for a ref. or a stand alone ice machine.  These would be different systems.  If it goes into a ref. what brand ref., and were you needing the whole ice maker kit or just the replacement ice maker.
Sorry about that, I should have included it into my 1st post. It is going into a newer Kenmore refridgerator with the freezer on the bottom. The ice maker would have been one that is built to fit it (new). I held off, because my drinking water comes from an RO unit and the pressure would usually be below the required pressure.  ( I asked about it on the board a while ago.)
Thats why I was wondering if there was such thing as a unit that can run with the lower pressure. I might just install it and try to see if I can get ti to work without spending too much on it.
Rod
