Hotpoint Dryer Problems
1 reply to this topic
#1 Guest_LAB_*
Guest_LAB_*
  • Lurking at the Threshold
Posted 12 April 2005 - 05:05 AM
Hotpoint Model NVL333GVOWW. The burner cylce starts normally but then shuts off after a period of time and never starts again. If I open the door and restart the cycle it restarts the burn cycle but then repeats the same problem.
Motor replaced 3 months ago due to bad bearing, gas solinoids replaces 1 year ago.
#2 Budget Appliance Repair
  • 3,996 posts
Posted 13 April 2005 - 12:18 AM
Sure sounds like the gas valve coils going out again.
Have you tried to run it with the vent off to make sure you don't have a vent obstruction?
Do you have an access door where you can watch the burner light up and see what the flame looks like? If so is the flame blasting down flame tube real good, not just a mussy flame because air is not being drawn through dryer correctly?
Check all the felt drum seals.
Check your model# again and see if maybe you didn't write something down wrong, I can't get it to come up on any of the reference sites I use.
William Burk (Willie)
Eureka, CA 95501
Eureka, CA 95501
