foryadog
Fisher & Paykel GW708 U
3 posts in this topic
The pump was burnt out, blew fuse on motor control board, replaced fuse and a new pump. Now the pump won't stop. When power first turned on the pump is running, advance to spin cycle, machine will spin and when finished all lights go out but pump is still running. Start cycle again, machine starts to fill but pump is still running and water is pumping out. Hope you can help.
Ron
This  is a common follow on effect of a burnt out pump.  The only way to repair this long term is to replace the motor controller.  I have had guys in the workshop try and fix the controller, but it only seemed to last a couple of weeks until something else went wrong.  M/controller P/N 426204p (NZ)
Thanks for the info. I was hoping it would not be the controller, now I have to spend some more money.
Thanks again,
Ron
