Whirlpool oven too hot!!!
3 replies to this topic
#1 Guest_Ovenguy_*
Guest_Ovenguy_*
  • Lurking at the Threshold
Posted 12 April 2005 - 10:41 AM
Hi, This is an electric stove/oven with the sealed glass burner top and electronic controls for the oven and timer. It is self cleaning.It is only a few years old. The burner top part works fine. Each burner has its own seperate knob and they all work fine. the problem is the stove. It was working fine. Then one day my wife went to use it and instead of just warming up to the set temperature it stayed on and the whole oven got super hot. So hot that it lit up the sensors on the top that indicate if a burner is still hot. There is no temperature regulation. It just stays on and doesnt cycle on and off to maintain any temperature. Also Ive noticed that the buttons on the digital display dont make a beeping noise anymore when depressed. Is there a seperate thermostat or is the whole thing one unit buit into the digital display part. I have no problem replacing the unit if its the problem. I dont want to replace the $150 part to find out that it wasnt the problem. Any help would be much appreciated. Thanks. model # RF368LXKQ
George
#2 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 12 April 2005 - 12:13 PM
Sound like to have a bad (short-circuit) electronic oven temperature sensor.
The Seven
#3 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 12 April 2005 - 02:20 PM
The force is telling me there is a relay on your ERC that has stuck or welded itself closed.
Seven would agree with me that if your sensor was not bad before it probably is now due to it's exposure to the extreme heat..
I would replace the ERC and the sensor.
This is only the force telling me this.  It is no substitute for pulling the back off with a meter in your hand.
#4 The Seven
The Seven
    Sōhei
  • 190 posts
Posted 12 April 2005 - 05:31 PM
Agreed with your "force". Jedi. :dude:
First check the sensor. :X
The Seven
