  • Announcements
westchasemom
Round Three with our Whirlpool LXR6232EQ0 - Can't Afford a TKO!
7 posts in this topic
This is round three with our Whirlpool LXR232EQ0.  The machine felt overloaded with two bathmats and the drum stopped spinning.  We checked the drive cam - the plastic parts and the rubber middle were perfectly intact.  Round two - we checked the basket drive (oh the joy of getting that rotten nut removed!).  The basket drive parts look fine, no metal shavings to be seen and the threads don't appear stripped on either the post or the part that sits between the post and the spanner nut.  What's round three?  We can't really afford to go buying a new machine but are quickly tiring of the laundromat (although there is a certain allure to getting seven loads of laundry done at the same time!).  Please advise!  Thank you!  M.
Did you check to see if the lid switch was broken??  Was the washer dead or was the motor running???  Does this have the off balance switch on the rear panel, could have broken it??? More information please.
The motor was running (at least, the machine was making a lot of noise).  I'll check to see if there's a balance switch (the diagram from repairguide.com didn't show one) and check the lid switch - although, the motor was making noise when the lid was closed - so I doubt that this was an issue - then again, I'm no expert!  Thanks for the feedback.
Yes, if the motor was running the lid switch and off balance if there is ok.  Where is the noise coming from???  the coupler was ok??   Check the pump, perhaps something is in there, remove the motor and lay it on the floor and run it by itself, if the noise is gone perhaps tranny??? Be sure the coupler is not cracked, that would sound like a jack hammer!!!  ;)
After hunkering down for Dennis, we're back to washing machine work!  I removed the pump and took a look inside (what of it I could see) and found no foreign stuff.  The part inside turns without much effort and the spindle that it attaches too can be easily turned in either direction by hand.  So, it's not the drive cam or the basket drive or the pump.  Tranny's next. Warning - nieve question coming up - Once I remove the motor - how do I test it alone (to see if the noise is coming from it or the transmission)?  If the noise is the transmission - what's my next step and what's it going to cost me?  As always, thanks for your help!  M
Do you have any additional advice for us?  We're on the verge of caving in and going with a new machine - something we really wanted to avoid.  Thanks so much!  M
If you take the cabinet off, and make a jumper to bypass the lid switch(small piece of romex wire), you can put the machine into spin and visually check clutch.
If you see the clutch drum going around, but the basket don't turn, you need to replace the basket drive, or at least the release lever.
The noise you may be hearing is the nylon teeth stripped out inside gearcase, then you need a new transmission.
