Learn how to troubleshoot like a Master Samurai Tech...
Kobayashi
Kenmore front loader (417.41142000) leaking
5 posts in this topic
I have a 4 year old Kenmore front loader.  My washer does not leak when the water is filling up or draining.  However when it goes into the fast spin after it drains, water starts to leak out the back.   I am assuming that the water is coming from what is being spun out of the clothes.  I had a repair guy come when my wife was around, amd  he could not reproduce the problem, but I think he ran the machine without anything in it.  She still had to pay him anyway :(.  I am getting really frustrated with this machine and am tired of mopping up water.  Is there a way to fix this, or should I go out and fork up the bucks for one of those new Whirlpools.
First, get your money back from that bozo or have him come back out at no charge and do what he should have done in the first place: reproduce the symptom under the exact conditions, that is, when the washer is actually washing a load of clothes. If he has to lay on the floor with the front panel off for the whole cycle to find the problem, so be it-- you hired him to find and fix the problem. If people start holding these schlocky parts changing money's feet to the fire, maybe they'll go back to digging ditches or working the toll booths.
This problem will be either a leaking pump, leaking pump boot, or leaking tumbler gasket. Pray to the buck-toothed Buddha that it's one of the first two things.
I going to try to get him to come back, but is there a way for me to figure out what the problem is before he comes?    Since it does not seem to leak when its pumping, why would the pump or pump boot leak when it is spinning fast.
Samurai's 4th Law of Appliance Repair illumines us in our time of need, "All leaks are visual."  Ah, yes, comforting words for trying times.  Inspired to go forth and conquer, you'll remove the front panel, start a load of wash, get a flashlight and lay on the floor.  Watching.  Waiting.
Watching.
Waiting.
BOO!
Does it make abnormal noise when it spins?
If so, the water could leak out from the drum bearing seal.
If no, there could be a hole on the upper half of the "plastic" outer tub. There was a previous case from this forum that a hole was cut by sharp metal object (screws left in the pockect of his workcloth) getting in between the stainless steel inner tub and the plastic outer tub. Any metal objects , like nails and coins, could cut hole in plastic tub easily.
Follow the "visual" inspection as suggested by our Grand Master.
