BoBo
Amana won't spin/agitate
4 posts in this topic
Amana washer (P)DLW330RAW will fill and drain, but will not spin or agitate. It makes a light click when lid closes which makes me think the lid switch is bad. I can't see where where the lid switch should be in the darn thing or if it fell off, under
Can someone point this out to me of where it is, how to test it, and how to replace if bad?
 I have an ohm tester - do not know how to use it :(
Thank you all, BoBo
Hello, my lightly clicking friend.  Your inclination to use your ohm meter to test the switch was an inspiration from Allah.  Our most dear and gracious host, Samurai Appliance Repair Man, has prepared a primer just for you on how to use your meter.  Would you like to see it?  Alright, it is here:
http://fixitnow.com/2004/12/appliance-repair-revelation-making.htm
Seems to me the light click when the lid closed would indicate the lid swich was working, no click would seem to be a problem tho.   But the lever could be clicking but the switch itself could be dead., anything is possible.  Is the motor running or is the washer dead??  Lid switch parts reference #,s 16, 18, 19.
Leadimage.asp?productTypeID=0153200&brandID=1268&modelDesc=AMANA%20LAUNDRY&modelNumber=DLW330RAW&documentID=M0501103&documentTypeID=PLDM&documentClassCode=PV&titleType=TOP%2C%20LID%20AND%20LID%20SWITCH&titleID=00003&
Moostafa and Pegi,
Turned out it was the belt. I've read a little about this, but if anyone has helpful tips to keep in mind, this grasshoppers' ears are open.
BoBo
