Kenmore Direct Drive washer WLC toasted?
3 replies to this topic
#1 zenguitarman
zenguitarman
  • 1 posts
Posted 12 April 2005 - 08:24 PM
I just replaced the motor coupler (it was definitely worn out- several pins were broken and half the rubber was disintegrated) on my Kenmore direct drive washer (MODEL 110-4680290) and did a test run. The tub filled but refused to agitate. It would spin if I advanced the timer manually. I drained the tub and tried another test run, but the washer would blow the 15A breaker as soon as I tried to start the fill cycle.
I've tried all sorts of troubleshooting - even testing the motor continuity and capacitor- OK- and have determined the pressure switch contacts are shorted in the FULL position. It also looks like the pull on/push off on the timer wwitch is also shorted closed. Could they both have been fused by whatever caused the breaker to blow?
I don't want to replace the pressure switch and timer unless I know they're not going to fuse again. This is 10 year old machine. Am i better off just cutting my losses and replacing it?
Thanks in advance!
#2 BrokenDirectDrive
BrokenDirectDrive
  • 1 posts
Posted 14 April 2005 - 07:50 PM
Just a question... how did you replace the coupler. I just found the rubber part of mine chewed up on the floor along with several broken teeth. I'm pretty confident I can get to the motor, but before I start I'm wondering if/how the coupling can be removed from the motor shaft and whatever else it is connected to on the other side.
Just a brief description of how you did it would be fine. Thanks!
  • 24,312 posts
Posted 14 April 2005 - 07:59 PM
Do you hear the motor running during the agitate cycle or does the machine go eerily silent?
  • 24,312 posts
Posted 15 April 2005 - 09:30 PM
Hey, Broken, this page awwta hepya.  :hodji:
