jimbo
Whirpool Electric Oven
4 posts in this topic
Model # RB262PXAB3 Approx 10 years old.
I have replaced the element but no luck. The Broiler element seems to heat up fine, but when I try Bake, it sounds like it's working, but it's not heating up. Help !
Need to see where you are losing voltage, could have a burnt wire or the clock could be defective, not feeding the element
Post your wiring diagram and we can help you trace through the circuitry.
remove the power first . now remove the rear panel we are looking for burned wiring , if none then you will need a volt meter this however will be a 1,2,3,4,5, step adventure i don`t suggest using a testing methode with the power connected so in your case i suggest you get a 9v battery and some wire  and report back for further info. i will walk you through the steps via the mirc(safety first).
