GE Profile key pad only gives me 8's
  • This topic is locked This topic is locked
4 replies to this topic
#1 Guest_Bambina369_*
Guest_Bambina369_*
  • Lurking at the Threshold
Posted 13 April 2005 - 11:15 AM
I have a GE profile range with a key pad issue. No matter what number I punch in, the only number that shows on the LED is 8. Sometimes if I hold the convection bake key while I'm punching in the numbers it will work, but if I'm not holding the convection key, the numbers only come up as 8. Nothing else works aside from convection bake. I can't even set the clock. Two other members in my family have GE profiles and have all had key pad issues. Is this a common thing?
  • 24,296 posts
Posted 13 April 2005 - 02:07 PM
Seen a fair amount of keypad problems with GEs. What's the model number?
#3 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 13 April 2005 - 02:12 PM
Some comments may apply to most applinances:
a) Induction motor is more robust than motor with "brushes and commutator". Brushes need replacement after several years of running. Speed control is easier when using motor with brushes.
b) Electrical timer controls give the least problem when compared with electronic controls. But electronic control is more precise and versatile.
c) Electrical switches give the least problem when compared with electronic "touch pads". Most "touch pads" use carbon film as electric contact and this carbon film is very thin and not lasting.
d) Electro-mechanical relays/switches could tolerate "overload" much better than electronic solid-state switches.
e) Without "overload", "heat" and "water", electronic would outlast electro-mechanical since there is not mechancial "wear and tear".
Your problem could be ©!:X
The Seven
#4 Guest_Bambina369_*
Guest_Bambina369_*
Posted 15 April 2005 - 12:06 PM
Model number JTP18W0W1WW
  • 24,296 posts
Posted 15 April 2005 - 03:07 PM
Can't get that ezzzact model number to pull up but I know GE has a had a horrendous problem with bad touch panels on their ranges.
