Wierd voltage readings on a 240 volt plug
44 replies to this topic
#41 Keinokuorma
Keinokuorma
  • 1,259 posts
Posted 20 May 2008 - 10:25 AM
So technically the transformer layout I posted a few messages ago could be wired to produce either Electrician Dude's Delta connection, or two of my Wye connections, or up to 416V output with neutral in the center. Versatile, huh?
"There is no reason anyone would want a computer in their home."
- Ken Olson, Digital Equipment Corporation (1977)
#42 slawomir
slawomir
  • 9 posts
Posted 06 July 2008 - 06:23 AM
What you've posted is a standard transformer with delta primary configuration and depending on secondary winding connectin it may be D/Y or D/D. Produced voltage depends on primary voltage and number of winding turns on primary and secondary side.
#43 gpedens
gpedens
    Ikkō-ikki
  • Chief Appliantologist
  • 25 posts
  • Flavorite Brew:Grape Nehi
Posted 07 April 2009 - 05:37 PM
Budget did you ever get your question answered on this one.  Three phase  208 is 120 phase to ground.  It sounds like you have a high leg delta.  It should have a orange colored. Do a google on high leg or wild leg 240 phase connection.  It is also in the NEC code.
Ifin you wannit dun rite do it yersef. The best way of doin sumpthin air as good as any.
#44 Budget Appliance Repair
  • 3,999 posts
Posted 08 April 2009 - 01:14 AM
Yes, it was discussed all in this here topic and was found to be exactly what you are saying.
William Burk (Willie)
Eureka, CA 95501
#45 gpedens
gpedens
    Ikkō-ikki
  • 25 posts
Posted 08 April 2009 - 02:43 PM
Glad to hear it.  it was late and I was too lazy to read the whole thread.  I have seen some on this subject before and they tend to get quite long.   Mike Holt NEC code forums and news letters are an excelent source.   Delta systems can give funky terminal to ground voltages.  And connecting neutrals from different supplies can get you in deep shoo shoo.
