Maytag Washing machine LAT8016AAE
4 replies to this topic
#1 Pilot
Pilot
  • 15 posts
Posted 29 March 2008 - 01:22 AM
Hello Sensei,  I'm back.  Was last here in Oct, 2007 with a shimmy problem on this great old washer.  The washer is performing fine now.  However, when adjusting the leg height this morning, I noticed more Orange (ish) grease/oil on the catch pan!  I noticed this in Oct last year but did not pursue it.  Me thinks now is the time to get this bug fixed before something breaks.  Any guidance would be greatly appreciated!
#2 Trying to help
Trying to help
  • 2,464 posts
Posted 29 March 2008 - 02:41 AM
Usually the fluids or lubes leaking on this unit that raises an alarm are dark brown almost black (tranny fluid).  Orangish grease like drips are usually just excess that has run or dropped down from a dab that is sometimes put on the motor glides, or springs and bolts of the suspension system.  The grease around the center seal in the mounting stem is orangish in color, but to have that in the pan, you would have water accompany it.  How much are we talking about and at what area's did you notice it?
If we saved YOU Beer $$ today, please make a donation to our beer fund by clicking the link below to help keep this site going. I charge $135.95 PLUS PARTS to do this repair!$! http://fixitnow.com/beerfund.htm
#3 Pilot
Pilot
  • 15 posts
Posted 29 March 2008 - 03:53 AM
Thanks for your reply.  The orange grease/oil is almost directly in the center of the machine.  There is no evidence of any water leak at all.  Not sure if it means anything but the spot is oblong not circular, almost as if it is dripping as the machine is agitating not spinning if it happened while spinning, I would think it would be more widespread.?  Quantity is approx 2 tablespoons.
Thanks for any input "Trying to help".
#4 Trying to help
Trying to help
  • 2,464 posts
Posted 29 March 2008 - 04:49 AM
On the center of your trans pulley is a black rubber cap that has a little orangish grease in it from the factory.  Is this cap on?  Does it appear to be the same grease that is either in the rubber cap or smeared on around the Phillips screw or drive lug the cap covers?  If we are only talking about a little bit, I would not worry about it.  If you are not seeing water below, or oil forced up into your tub, it sounds like just lube that has dripped from the years.  If your lower trans seal was bad (lip seal), you would have black trans oil leaking down the center of the shaft.
#5 Pilot
Pilot
  • 15 posts
Posted 29 March 2008 - 05:27 AM
4 Roga, Trying to Help.  Appreciate your thoughts.  Will check and report back.  :D:guzzle:
