JENN AIR JCD2389GES cond.will not run.
12 replies to this topic
#1 BAKINS50
BAKINS50
  • 6 posts
Posted 11 April 2008 - 04:55 PM
My JENN AIR JCD2389GES has been in storage for about a year. I finely got it out and plugged it in and it will not cool. I can hear the fans run, but nothing else; no comp. etc. is there a reset somewhere or is this comp. bad?
  • 24,218 posts
Posted 12 April 2008 - 01:03 AM
I'd start at the cold control (item 3). These old-style controls use a gas-filled tube sense temperature and are famous for leaking verrrry slowly, eventually becoming stuck open. Unplug, disassemble, and use your meter to check continuity as you rotate the knob shaft on the control.
#3 RegUS_PatOff
  • 30,201 posts
Posted 12 April 2008 - 01:40 AM
If the fans are running, the cold control is probably OK.
See if the fans stop when the control is turned to OFF
similar wiring diagram:
#4 BAKINS50
BAKINS50
  • 6 posts
Posted 12 April 2008 - 03:09 PM
If you are talking about the temp control in the frig., if i slide them to the warm side as far as they will go the fans stay on. I am thinking maybe it might be the relay or the  Run capacitor on the comp.is there a way to check it?
#5 RegUS_PatOff
  • 30,201 posts
Posted 12 April 2008 - 03:23 PM
Although the warmest setting on the temperature control is still colder that the fridge (room teperature) ...
If you could do some voltage checks on the compressor as shown in the wiring diagram above.
ORANGE = neutral
BLUE = 120v supply
There should be 120v between BLUE and one of the connections on the RUN CAPACITOR (on certain models only)
With the fridge un-plugged:
You could check the resistance of the overload.
You could make sure niether of the compressor's 3 terminals is shorted to it's case.
You could also check the resistance of the compressor windings.
         Common
1 - 5 Ω          3 - 11 Ω
Start                   Run
Check the resistance across the (removed) PTC device (should be between 3 - 20 OHMS)
#6 BAKINS50
BAKINS50
  • 6 posts
Posted 12 April 2008 - 03:44 PM
Thanks I will check it tomorrow[/b]
#7 BAKINS50
BAKINS50
  • 6 posts
Posted 14 April 2008 - 04:33 AM
ORANGE = neutral
BLUE = 120v supply
There should be 120v between BLUE and one of the connections on the RUN CAPACITOR (on certain models only) THERE IS
You could make sure niether of the compressor's 3 terminals is shorted to it's case. ARE NOT
         Common
1 - 5 Ω          3 - 11 Ω
Start                   Run
GOOD                 GOOD
GOOD
What next ?
#8 RegUS_PatOff
  • 30,201 posts
Posted 14 April 2008 - 06:58 AM
Is the overload switch OK  0 ohms ?
120v is supplied through the overload switch to the Common terminal of the compressor.
The capcitor is connected across the Start & Run terminals.
Neutral is connected to the Run terminal.
During starting, the PTC relay applies the neutral (through it's low internal resistance) to the Start terminal of the compressor.
As the resistance inside the PTC rises, it reduces the neutral connection to the Start terminal.
#9 BAKINS50
BAKINS50
  • 6 posts
Posted 14 April 2008 - 11:57 AM
On the side of my comp. there is a sq. tan box with the blue wire on the bottom,and the orange and white on top. with this removed from the comp. what points should read 0 ohms? If this is the overload switch .
#10 RegUS_PatOff
  • 30,201 posts
Posted 14 April 2008 - 01:15 PM
that could be it.
should be only 2 connections 0 ohms...
#11 BAKINS50
BAKINS50
  • 6 posts
Posted 14 April 2008 - 01:53 PM
i'm getting about .5 ohms, this most be the
Problem. thanks for your help.
#12 RegUS_PatOff
  • 30,201 posts
Posted 14 April 2008 - 02:01 PM
.5 ohms should be OK
#13 RegUS_PatOff
  • 30,201 posts
Posted 14 April 2008 - 02:14 PM
One voltmeter lead on Blue (one side of overload)
Other voltmeter lead:
Orange/white (?)  other side of overload  0v
Capacitor Orange 120v
Capacitor White 120v during start
