Update: Frigidaire Front Loader FWT647GHSO - Bearing, Tub Seal, Squeaks
#1
Posted 14 April 2005 - 06:10 AM
Symptoms: black marks on clothes. occasional splotches.
First hypothesis: dreaded bearing seal failure
Rear Bearing evaluation:
I took off the rear bearing outer seal, cleaned it with solvent and compressed air, and everything was bright and shiny and quiet. I put the washer back together.
Result: There are two bearings, evidentally. I cleaned the outer. The inner is inaccessible unless you open up the whole outer tub. The inner bearing continues to leak grease on the clothes.
Conclusion: Frigidaire/Electrolux sucks. I called cust svc and got the normal reply: After you fork out for a service call, we'll consider giving you a rebate on a new purchase, or prorate the parts cost, you pay for the labor for the repair.
Thanks guys..... Rob
#2
Posted 14 April 2005 - 06:24 PM
I'm tempted to say this is designed obsolescence except this would be ascribing too much skill to the Electrosux engineers; I think instead it's another example of engineering incompetence in the appliance world (a la Maytag Neptune).
FWIW, I'm attaching a pdf file that someone made on how to replace the rear bearing.
#3
Posted 18 April 2005 - 05:36 PM
#4
Posted 19 April 2005 - 03:37 AM
Have they done another redesign yet to fix it? Or is it even recognized as a problem?
#5
Posted 19 April 2005 - 03:40 AM
It is weird that they couldn't leave well enough alone. Friggidaire has expressed no recognition of this problem and I've not seen a service bulletin on it.
#6
Posted 19 April 2005 - 07:34 PM
#7
Posted 06 June 2005 - 06:38 PM
#8
Posted 05 August 2005 - 03:00 AM
#9
Posted 05 August 2005 - 03:47 AM
One visual check in advanced cases is to remove the rear panel and look for the brown goo emanating from the bearing.
#10
Posted 05 August 2005 - 05:16 AM
#11
Posted 05 August 2005 - 05:25 AM
#12
Posted 06 August 2005 - 02:23 PM
#13
Posted 11 January 2006 - 07:35 PM
the repair people told me not to bother repairing it - because the job was to big.
I'm loooking into a new washer now - I will definatly call frigidare to complain.
Hss anyone had luck getting anything form frigidaire in terms of compensation?
#14
Posted 11 January 2006 - 07:50 PM
#15
Posted 04 January 2008 - 03:34 AM
#16
Posted 04 January 2008 - 09:55 AM
#17
Posted 04 January 2008 - 10:02 AM
#18
Posted 04 January 2008 - 10:48 AM
http://www.fixitnow.com/beerfund.htm
#19
Posted 10 July 2009 - 07:20 AM
Mike Cook
Senior Engineer, Cornell High Energy Synchrotron Source
#20
Posted 10 July 2009 - 08:00 AM
