handyman
GE Profile Arctica Side-by-Side
4 posts in this topic
I cannot get the water dispenser to work on my refrigerator.  It has worked in the past, but quit a while back.  I have tried to figure out what the problem is, but have been unsuccessful.  Would it matter if I went ahead and swapped out the water filter??  Any help would be appreciated.  :?
A model number and age might help.  Is that all that's wrong?  Is it freezing things in the fresh food side? Do you have a meter or test light?
The model number is PSS25NGMB WN (I believe that is it.. It is hard to read the guys writing on the manual)...  It is about 3 years old now.  No other problems that I can see.  It did freeze up one time, but I do not believe that is the problem now. I do have a voltmeter if that is what  you are asking...
Could be:
The solenoid valve
or frozen tubing near the reservoir
#810 812 in the picture below
Could be a broken damper (#426 in the picture above)
could be frozen water tubing inside the freezer door or even the switch on the door (#72 in the picture below)
A good starting point might be put your ear to the fridge and try to dispense a glass of water.  Do you hear the click of the switch?  Do you hear the hum from the solenoid?  Is the solenoid getting power when it is supposed to,  but not doing what it's supposed to when it's getting power?
You can remove that valve assembly from the fridge with out disconnecting it so that you may check it.  Just be carefull when cramming it back in.
